Go to Post Some call those dreams- others nightmares - Wayne C. [more]
Unread 17-02-2010, 19:32
adamdb adamdb is offline
adamdb has a spectacular aura aboutadamdb has a spectacular aura aboutadamdb has a spectacular aura about
Can't reimage cRIO after latest update
We installed the latest updates of Labview, DriverStation, and Netbeans. Of course, when we tried to download a program to the cRIO it told us that we were using v19 and needed v20 (on the cRIO). So we tried to reimage the cRIO with the v20 firmware and can't. We tried it from two different computers that have the latest updates installed, several different network cables, insured that firewalls were off, etc., etc. We had not had any issue reimaging the cRIO prior to this and had reimaged with the v19 firmware several times successfully. When we bring up the Image utility, it does find the cRIO at 10.15.83.2 just like it should. When we select "Format Controller" and the v20 firmware, it says "Connecting to cRIO" and eventually times out and tells us that the IP can't be found. This sounds like a firewall issue, but I'm sure that firewalls are off on both laptops and that everything is configured like it was when we could successfully image the cRIO.
Is anyone else having this issue?
Adam Bryant
Programming Mentor
Team 1583
Ridge View Academy Rambotics
Can't Find Latest cRIO update!! siriustuck13 Control System 2 17-02-2010 14:04
can't Download code to cRIO oddjob C/C++ 13 14-02-2010 12:27
Can't recompile Default Code after v11 upgrade Travis Hoffman C/C++ 0 31-01-2009 09:53
[wiki]: Update to latest Mediawiki version? cbale2000 FIRSTwiki 2 30-04-2008 12:33
Latest Update Released!! New Rule <PCL 1.1> Rich Kressly General Forum 3 30-03-2005 18:22
