Go to Post If you want to make change, you have to know what you're trying to change. - [more]
Unread 17-02-2010, 20:17
chdmwu chdmwu is offline
FRC #1351
chdmwu is an unknown quantity at this point
Weird issue "No Robot Code"
We have a weird error where the Classmate says that there is no robot code. We've isolated a line that is causing this.
This code:
// case COCKED:
// if(_kicking) {
// float my_setpoint = (float)FindNextSafeSpot(1);
// _pid.SetSetpoint(my_setpoint);
// //TODO: cocked stuff
// break;
seems to be the problem, specifically the SetStpoint stuff. It looks like FindNextSafeSpot() is causing this. We changed th code there and have it just returning 1, but this is still causing the problem. If we comment this line out, however, the Classmate has no problems.
We found another thread with this problem and the issue was that the person was missing an -mlongcall linker flag. We checked and we do have this flag, so that's not the problem.
Has anyone else encountered this error, or does anyone have any idea what to do? We've been dealing with this all week.
Thanks!
Chris Wu - Team 1351.
Unread 08-02-2011, 23:34
Jonathan W.'s Avatar
Jonathan W. Jonathan W. is offline
FRC #1351
Jonathan W. has a spectacular aura aboutJonathan W. has a spectacular aura aboutJonathan W. has a spectacular aura about
Re: Weird issue "No Robot Code"
HI CHRIS!
Unread 09-02-2011, 00:40
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
When you get a No Robot Code error, that usually means that there was an error before the FRC_UserProgram (or something similar) task was called, thus causing there to be "no code." Try running the NetConsole with the broken code uncommented and see what errors, if any, it outputs.
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 09-02-2011, 21:15
Arjun Namineni Arjun Namineni is offline
FRC #4384
Arjun Namineni is an unknown quantity at this point
I encountered a similar problem the other week, and all I had to do was reimage the cRio. I'm not sure if it is the same problem for you, but it worked for me.
2009-2013: FRC 226 - Student
2014-Present: FRC 4384 - Mentor
Unread 12-02-2011, 14:22
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
If you try deploying to the cRio as a run configuration, runtime errors can appear (such as unresolved symbols).
"No Robot Code" problem Deep-Blue C/C++ 4 14-02-2010 17:57
"No Robot Code" error? plus other issues... 3195mentor NI LabVIEW 3 13-02-2010 08:20
G-FORCE's robot, named "philbot" a.k.a "armagedon in a polycarbonate box" Bryan_2818 Robot Showcase 0 12-04-2009 20:54
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
