Go to Post A thread already exists (and boy, does it exist!) on the topic: - Billfred [more]
Unread 17-02-2010, 20:34
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Usage of part - unclear as to commercial availability
I found in one of my team's bins an IR receiver/emitter set that we'd like to use for ball detection. I was able to find it on the web at http://www.mro-supply.net/servlet/th...OSWITCH/Detail
I think it was in the KOP a few years back, and the description of COTS in the manual (and to when it could be used) confused me.
Thank you!
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 17-02-2010, 20:40
TomH's Avatar
TomH TomH is offline
FRC #0087
TomH has a spectacular aura aboutTomH has a spectacular aura aboutTomH has a spectacular aura about
Re: Usage of part - unclear as to commercial availability
When you say ball detection, do you mean as in that is it in the possession of your robot, and if it is, why not use a limit switch? I understand that a limit switch requires contact with the ball, but in the long run, it may be better, and since it is a physical switch, and not beam that is expected to be reflected back, it also may be more reliable as well in my perspective. If it came in the KOP a few years prior, and it is UNMODIFIED, then it is considered as a COTS since it was available to all teams. Hope that clears up some things.
Unread 17-02-2010, 20:47
Lead Programmer
AKA: Socks
No way to mount a limit switch. Also, this doesn't reflect light - it's two seperate units. (Emitter and receiver)
Thanks for the suggestion.
Unread 17-02-2010, 20:55
TomH's Avatar
FRC #0087
Okay, well, my first post, after very close inspection to the manual, may be misleading. If you plan to use the IR sensor in it's stock, original form, it is still considered a COTS component. It is when you modify it where it becomes custom. In order for it to stay as cots, MAKE SURE IT IS COMPLETELY UNALTERED, and you'll be fine.
Unread 17-02-2010, 20:58
Lead Programmer
AKA: Socks
Now, would it have to be COTS to be used on the robot?
Also, would shortening wires make it no longer COTS? Each component came with 10 feet of wire.
Unread 17-02-2010, 21:08
TomH's Avatar
FRC #0087
It doesn't have to be COTS to be used on the robot, my post was incorrect before, it is now edited. By cutting down the wire, it most likely will lose its COTS label, ex form manual:
Example 1: a team orders two robot grippers from RoboHands Corp. and receives both items. They put one in their storeroom and plan to use it later. Into the other, they drill “lightening holes” to reduce weight. The first gripper is still classified as a COTS item, but the second gripper is now a “custom part” as it has been modified.
(Page 4, Section 8, under COTS)
It will be still considered legal, but most-likely will be considered a "custom part".
Also, I apologize for any misleading information in my first post in this topic, I was too at one point confused. I recommend that if you are still confused, you read the manual, specifically page 4 of section 8, to get a better understanding. By modifying it to say reduce the length of a cable, it may be considered "custom" because you have changed it from its original commercial form. The only things that COTS gives a specific object is that it was entirely unaltered, and if removed, looks exactly as it did when taken out of the box.
Unread 17-02-2010, 22:23
Electrical Engineer
Rookie Year: 1995
Thank you!
Ethan,
If you want clear guidance, you should post your question to the GDC.
In my opinion, the use of this part, as described, would be classified as a "custom circuit" and must adhere to all custom circuit rules.
Good luck.
Mike
Mike Betts
As easy as 355/113...
Unread 18-02-2010, 08:00
Ethan,
More importantly, one of the tests for COTS items is that they are available to all teams this year. Since your part has a variety of suffix identified versions, your version may not be an exact part that is available this year. I do not remember this part coming in the KOP. I don't know if the GDC has ruled on wires cut to length as a modification. Additionally, but more confusing...
<R33> COTS items from ROBOTS entered in previous FIRST competitions or COTS items that are no longer commercially available may be used under the following conditions:
A. The item must be functionally equivalent to the original condition as delivered from the VENDOR (e.g. a part that has non-functional label markings added would be permitted, but a part that has device-specific mounting holes added would be prohibited), and
B. The item must satisfy ALL applicable 2010 FRC materials/parts use rules.
If you really want to use it, the GDC is the only official answer.
Solid Works availability betsy888 SolidWorks 4 15-02-2010 17:54
2060 attachment chain availability Bruceb General Forum 6 20-12-2008 10:12
IR Receiver Availability at Events OZ_341 General Forum 13 25-03-2008 11:08
Availability of Mach Listing Eko Programming 3 26-02-2006 21:54
Drill Motor Availability archiver 2000 1 23-06-2002 23:43
