Go to Post FIRST describes this program as students working "side by side" with professional mentors. We describe our team as working "shoulder to shoulder." Maximum learning happens with maximum interaction between students and mentors, whenever and wherever that may be. - jspatz1 [more]
  #31   Spotlight this post!
Unread 17-02-2010, 15:51
killerofall killerofall is offline
FRC #2611
killerofall is an unknown quantity at this point
Cool WAY underweight
My robot is going to need lead blocks- we are at 90 pounds and pretty much done. we have now foregone aluminum in our construction so that we have more weight...
  #32   Spotlight this post!
Unread 17-02-2010, 17:09
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Re: WAY underweight
We were at about 80 before we added our latching mechanism hopefully all the other stuff that will ultimately end up on the robot will not put us overweight 10 lbs like last year
-Alex
2010 Washington DC Regional: Engineering Excellence Award
  #33   Spotlight this post!
Unread 17-02-2010, 17:16
Smoores's Avatar
Smoores Smoores is offline
AKA: Steve Moore
FRC #2272 (Metalheads)
Team Role: Student
Smoores will become famous soon enoughSmoores will become famous soon enough
Re: Overweight!?
Well, its a heck of a lot better than our rookie year, where we showed up at the competition weighing 150 lbs. This year we are weighing 100 lbs, and its done. So I guess we can actually use those 25 lb lead weights we had.
Aviation in itself is not inherently dangerous. But to an even greater degree than the sea, it is terribly unforgiving of any carelessness, incapacity or neglect.
2007 Championship Highest Rookie Seed - Galileo
2007 CA Rookie All-Star
2007 CA Highest Rookie Seed
  #34   Spotlight this post!
Unread 17-02-2010, 19:42
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
Re: Overweight!?
Our robot is 100 lbs and we are 99% done. We first checked the weight last Monday and we were at 86 lbs then. We were so happy that we were so much under.
  #35   Spotlight this post!
Unread 17-02-2010, 19:48
PWelsh PWelsh is offline
FRC #2360 (POWER Storm)
PWelsh is an unknown quantity at this point
Re: Overweight!?
Because of the height of our robot this year we are having no troubles staying under weight. The other night we put everything we had done and everything we think needed to finish plus a little more and we were well underweight. This is my fifth year in FIRST and for the first time i dont see any problems with our weight.
Phillip Welsh
POWER-Storm 2360
  #36   Spotlight this post!
Unread 17-02-2010, 20:13
Chris is me's Avatar
AKA: Pinecone
Re: Overweight!?
~95 pounds with no robot cover. A hanging mechanism would probably bring that to 105 if that gets on. If the bumper frame (and hanging mechanism) are shipped, and 4 CIMS are removed to their COTS base, we're within 15 pounds of witholding. I suspect with strategic lightening, shipping of portions of the robot (replace with a spare in the shop, leave spare home to compete), we could get the robot chassis and ball manipulation down to 65. That's kind of a pipe dream, though... There's only so much you can revert to a non FABRICATED ITEM configuration on a robot.
  #37   Spotlight this post!
Unread 17-02-2010, 21:09
FlyingHedgeHog's Avatar
FlyingHedgeHog FlyingHedgeHog is offline
AKA: Jonathan
FlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud of
Re: Overweight!?
We're looking at being 10-15 lbs underweight.
  #38   Spotlight this post!
Unread 17-02-2010, 21:43
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: Overweight!?
We're at 112 pounds with the battery (no bumpers), so it's around 98 pounds unloaded. We're going to add some small steel bars and 1/4 inch polycarbonate for a cover of the power distribution board and advertising logos, so unloaded it would come to around 110 pounds.
  #39   Spotlight this post!
Unread 17-02-2010, 22:47
dmlawrence dmlawrence is offline
MIT '14
FRC #1751 (Warriors)
dmlawrence is an unknown quantity at this point
Re: Overweight!?
We ended up with a 17" tall robot weighing 128 lb.
As we like to say, the laws of physics don't apply here...
  #40   Spotlight this post!
Unread 18-02-2010, 12:01
BenX02's Avatar
BenX02 BenX02 is offline
FRC #2655 (The Flying Platypi)
Team Role: Driver
BenX02 has a spectacular aura aboutBenX02 has a spectacular aura about
Re: Overweight!?
40lbs under at the moment.
If needed, we're going to ad weights to the bottom to lower our center of gravity though.
  #41   Spotlight this post!
Unread 18-02-2010, 14:18
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Re: Overweight!?
2502 is about 15 lbs under with a few very small parts left to add (we have large things to add still, but we laid them on the bot when we weighed it so they would be included), small parts are basically a few sheet metal things and a sensor or two.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
  #42   Spotlight this post!
Unread 18-02-2010, 14:30
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
Re: Overweight!?
176's robot is hovering around 110lbs by our calculation right now. When we get the last few bolts in, and put our plexiglass cover and electronics on today, we'll weigh it all together, and it will *hopefully* be a few pounds under 120. We reached our estimate of 110 by taking all of the robot's pieces we had already made and putting them on our scale. Obviously, not completely accurate, but pretty close for now. Our bumpers, however, are RIGHT at 20lbs. Actually, they might be a few ounces over, but I couldn't tell when I weighed them because our scale isn't digital.
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
  #43   Spotlight this post!
Unread 18-02-2010, 14:32
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: Overweight!?
bumpers are supposed to way 15lbs...arent they?
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #44   Spotlight this post!
Unread 18-02-2010, 15:04
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Overweight!?
<R07> G. Each set of BUMPERS (including any fasteners and/or structures that attach them to the ROBOT) must weigh no more than 20 pounds.
A complete set (meaning all the bumpers that are on the robot during a single match - for a typical robot with a kit-bot frame, that would be 4 bumpers, one on each side) can weigh, at most, 20 pounds.
  #45   Spotlight this post!
Unread 18-02-2010, 19:20
Michael Ogden Michael Ogden is offline
AKA: Rules Expert
FRC #0135 (Penn Robotics)
Team Role: Student
Michael Ogden has a spectacular aura aboutMichael Ogden has a spectacular aura aboutMichael Ogden has a spectacular aura about
Re: Overweight!?
We are at 86.6 lbs, with a few more trinkets (i.e. the control board) to add, but those don't weigh more than 33.4 lbs (at least I hope not), plus 14 lbs of bumpers. We might actually have to add weight. O_o
Team 135 is attending Kansas City, Boilermaker, and hopefully Championship.
The preceding has been my opinion/advice/whatever, paid for with my $0.02.
Don't drink mt. dew after eating chili!
Are You EPICALLY overweight? ZakuAce General Forum 89 17-02-2009 09:34
About being overweight and exceeding your size requirements – the need for reinspecti Godzilla! General Forum 48 28-03-2006 11:11
pic: 7 lbs overweight CD47-Bot Robot Showcase 9 23-04-2004 02:27
OVERWEIGHT COOKIE General Forum 18 14-02-2002 07:53
