Go to Post The events are not just a competition, but a celebration of 6 weeks of hard work. - ChristinaR [more]
Unread 16-02-2010, 18:37
PlaidPillagers's Avatar
PlaidPillagers PlaidPillagers is offline
FRC #2538 (Plaid Pillagers)
PlaidPillagers is an unknown quantity at this point
Vision/AxisCamera2010.h
After the update to 4.2, WindRiver can't find the Vision/AxisCamera2010.h file.
Without it I can't use any of my camera code. I tried the work around suggested in other threads by Heydowns, but that didn't change anything.
Could someone help me please?
Thanks,
Matt
Team 2538
Plaid Pillagers
Morris, Minnesota
Rookie Year 2008
Unread 16-02-2010, 19:19
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
Re: Vision/AxisCamera2010.h
Try this:
#include "Vision/AxisCamera.h"
At least you'll be able to compile your code. But if you have been reading the threads here, the camera code is apparently broken in the latest software. YMMV.
Unread 16-02-2010, 19:23
kennypu kennypu is offline
FRC #2467
kennypu is an unknown quantity at this point
yes, if you use the latest one, its broken without using a patch, if you updated to 4.1 just do what oddjob said.
Unread 16-02-2010, 23:20
Thanks, I got that working.
But now, my drivers station is telling me there is no robot code. I rebuilt the code, reimaged (v20 still), rebooted everything, and repeated. No luck. Any ideas?
Team 2538
Plaid Pillagers
Morris, Minnesota
Rookie Year 2008
Unread 17-02-2010, 00:29
Each time you reimage, you erase any user code that might be on the cRIO in the process. You have to put your program on the cRIO after loading the v20 image.
Unread 17-02-2010, 00:34
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
If you are running WPILib 4.1, then any use of the DriverStationLCD class will crash robot code, sending that error. If using 4.2, then use of the AxisCamera class will crash code. I know, it's stupid
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 17-02-2010, 03:08
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Nothing changed with the camera code between 4.1 and 4.2. 4.2 just recompiled to make a symbol be found. The camera code was pretty much completely rewritten for update 4.1, so expect to retrofit a few things here and there if you were already using it.
-Joe
Unread 17-02-2010, 12:55
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
if i may make a suggestion, if it is saying an unresolved symbol after the update why not use the FIRSTForge svn to just pull down the .h and .cpp files and put them directly into the project, much simpler than trying to patch a precompiled library in my opinion.
just my two cents though
if someone can't find the needed files i think i could dig them out of my project and put them back to normal, just let me know
Unread 17-02-2010, 16:09
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
-Joe
Joe,
The 4.2 precompiled WPILIB does not have the camera code in it. I duplicated this from the sources in firstforge. First, I checked out the latest sources, created a workbench project from them and did a build. That build had the DriverStationLCD kLineLength symbol problem. I got around this bug by moving the const declaration out of the DriverStationLCD class into the file scope. Then I did a build of the WPILIB again. The result of that build has the problem with the missing AxisCamera that many people are reporting. Thinking that there might be a problem with the make dependencies, I did a clean of the whole WPILIB project and rebuilt the whole thing. The library that resulted from this build does not have the kLineLength problem nor does it have the AxisCamera problem either.
My guess is that the WPILIB that is in the 4.2 release was built after changing only the DriverStationLCD code and the AxisCamera code was left out. Doing a clean build should resolve the problem.
Unread 17-02-2010, 18:18
Okay, so I've isolated my problem. It's the axis camera.
Whenever I download code that uses the camera, the drivers station says "No robot code"
I'm not getting any error messages at all, it just doesn't work.
Has anyone found a work around/patch/other solution? I need to do a lot of coding for my camera still....
P.S. does anyone know if WPI/FIRST is fixing this?
Team 2538
Plaid Pillagers
Morris, Minnesota
Rookie Year 2008
Unread 17-02-2010, 19:26
Brad at WPI is looking into this.
Unread 17-02-2010, 19:27
A work around was explained in the post before yours.
Unread 17-02-2010, 20:33
Originally Posted by Mike Mahar View Post
Joe,
Could anyone go into a bit more detail on how to do this please? Thank you.
Team 2538
Plaid Pillagers
Morris, Minnesota
Rookie Year 2008
Unread 17-02-2010, 21:25
AKA: Ian Thompson
Easiest way is to get an account on FirstForge and get the source through svn. Windriver should be able to compile the code for WPILib and you just replace the current executable
Unread 17-02-2010, 21:35
AKA: Brad
#0190 ( Gompei and the Herd)
I just rebuilt the library and posted it at:
http://first.wpi.edu/FRC/frccupdates.html
Please give it a try by installing the update and relinking. Let us know if it works.
Sorry for the confusion, I think we hit some limit in the library that's making the build process somewhat unpredictable.
Brad Miller
Robotics Resource Center
AxisCamera2010.h not found d4mation C/C++ 2 13-02-2010 14:05
Vision Assistant Sykan NI LabVIEW 1 17-01-2009 16:43
Vision Illuminators Qbranch Programming 3 10-01-2008 03:20
n.e.r.d. vision feedback MattK General Forum 15 05-07-2006 20:11
n.e.r.d. Vision Episode 3! MattK General Forum 15 05-07-2006 13:06
