Go to Post Yay for teaching how to fish! - RoboMom [more]
Unread 17-02-2010, 21:40
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Can't reimage cRIO after latest update
I ran into this problem with the v20 update. If you have the BlackJagSerialBridge plugin installed, uninstall it. It blocks the update for some reason
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 17-02-2010, 22:03
misko misko is offline
FRC #0852
misko is an unknown quantity at this point
We had a similar problem. The 2CAN plugin also causes an issue.
If you edit the ni-rt.ini file and remove the reference to either the BlackJag plugin or the 2CAN plugin, then the update may succeed. It took 2 tries after I removed the reference, but then it worked fine.
Can't Find Latest cRIO update!! siriustuck13 Control System 2 17-02-2010 14:04
can't Download code to cRIO oddjob C/C++ 13 14-02-2010 12:27
Can't recompile Default Code after v11 upgrade Travis Hoffman C/C++ 0 31-01-2009 09:53
[wiki]: Update to latest Mediawiki version? cbale2000 FIRSTwiki 2 30-04-2008 12:33
Latest Update Released!! New Rule <PCL 1.1> Rich Kressly General Forum 3 30-03-2005 18:22
