Go to Post CAD or it didn't happen - R3P0 [more]
Unread 17-02-2010, 12:46
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Stuck in Teleop Init
This is a request for help based on quick and preliminary observations. Has anyone come across a robot becoming stuck in the "Init" state while in Teleop mode? It seems we are not advancing into the "Default" derived robot state. On the dashboard no error messages are displayed, the elapsed time continues increasing, and the joystick indicator lights show data is being read from the joystick. However, when running the code, the value of the derived robot state remains at init, and none of the default code executes. What drives this change?
Note: due to problems with the Watchdog, we temporarily removed it from the code.
Unread 17-02-2010, 14:14
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Stuck in Teleop Init
What environment are you using? LabView, Java, or C++?
Have you change anything since it worked?
Gyros can take some time to initialize if you let the robot sit for ~1 minute does it work? Also some of the eariler camera APIs could hang if the camera isn't connected.
Are there any messages displayed in your programming tool?
Please post the code in RobotInit() and TeleopInit().
Eric Haskins KC9JVH
Unread 17-02-2010, 21:51
I wish I could remember exactly what was going on when this happened to us a couple of days ago. I can tell you that I discovered one vi stuck in a loop. If you run Robot Main interactively, you can look at the "run" button of each SubVI it calls. Some of them will be in the black "running" state. Some of them might be white with a black line or dot, and hovering the mouse pointer over it tells you that vi is "waiting to run". That might give you a clue about where to focus your attention.
Unread 18-02-2010, 06:30
The code that drives the change is the Get Mode which is called in Robot Main. Be sure you are probing the correct wire. Also, it may be useful to put breakpoints in the different teleop sections to see where you are getting.
Greg McKaskle
Unread 18-02-2010, 09:58
It seems now that we are getting to Teleop Execute. Now all of the RefNum Get calls we have are returning errors. They've all been set correctly in Begin.vi, so I'm not sure what's going on.
Unread 18-02-2010, 13:38
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
That sounds like you might've run the Teleop VI instead of the RobotMain.
Whenever you run/deploy the code, you should always do it from the RobotMain. If you simply press the Teleop RUN button, then it doesn't load the other VI's (like the Begin.VI).
Just a guess ...
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 18-02-2010, 15:28
Just a guess ...
And a very good guess, but this is definitely not the case here. I always make sure that I am running robot main, and have followed the execution through Begin.vi and into Teleop.vi.
P.S. - this is a very good thing to do, because there are things we didn't touch that used the default RefNum names (e.g. Disabled.vi uses "Left and Right Motors" for drive) and will only give a one time error. Stepping through eliminated a lot of these problems.
TeleOp Init/Stop vs. Auton-Iterative Init/Stop Ziaholic NI LabVIEW 11 07-02-2010 22:19
adding a second joystick to TeleOp Init smcmahon NI LabVIEW 14 17-02-2009 20:43
Wierd basic init Jeremy J Programming 5 06-02-2003 11:42
Basic Init Error yan184 Programming 5 14-12-2002 13:10
