Go to Post FIRST is not the end...it is the beginning - Greg Needel [more]
Unread 17-02-2010, 22:03
misko misko is offline
FRC #0852
misko is an unknown quantity at this point
Re: Can't reimage cRIO after latest update
Originally Posted by Radical Pi View Post
I ran into this problem with the v20 update. If you have the BlackJagSerialBridge plugin installed, uninstall it. It blocks the update for some reason
We had a similar problem. The 2CAN plugin also causes an issue.
If you edit the ni-rt.ini file and remove the reference to either the BlackJag plugin or the 2CAN plugin, then the update may succeed. It took 2 tries after I removed the reference, but then it worked fine.
Can't Find Latest cRIO update!! siriustuck13 Control System 2 17-02-2010 14:04
can't Download code to cRIO oddjob C/C++ 13 14-02-2010 12:27
Can't recompile Default Code after v11 upgrade Travis Hoffman C/C++ 0 31-01-2009 09:53
[wiki]: Update to latest Mediawiki version? cbale2000 FIRSTwiki 2 30-04-2008 12:33
Latest Update Released!! New Rule <PCL 1.1> Rich Kressly General Forum 3 30-03-2005 18:22
