pic: Team 935's Chassis
Re: pic: Team 935's Chassis
It's not gonna crumple if a robot falls on it right? Plus why the 80-20?
I do like the triangular and circular cutouts but it seems like too much was taken out. Is there an arm? How much does it weigh? Very interesting. |
... How many CIMS is that? I think it might be over 5, and you're only allowed 5...
I only see 4 CIMs, all on the drivebase. I also see a window motor in the far back corner.
Oh, I see. Sorry, these hours must really be getting to me.
nice, a low mecanum robot that climbs, i wanted to do something like that but with non driven omni wheels, hope to see you compete
#7
I wouldn't worry about that too much, it's been a robust concept since 2006.
http://team935.com/media.php?photos |
#8
Why did you CNC so much? I only ask because to me it would make more sense to build a separate upper frame instead of extending the CNC so high up.
#9
http://www.chiefdelphi.com/media/photos/34715 Their triangular pattern is very strong. Even with pocketing, the pattern plus the fact that it is quarter-inch 6061 allows their frame to be very rigid and strong. It will not "crumple." Last edited by Akash Rastogi : 18-02-2010 at 00:13. |
#10
Hmm, VERY interesting. It appears to me that when your robot is flat on the ground (like it is now) the middle four, non-mecanum wheels, are off the ground? So that would mean that they are only for getting over the bump. At least, it LOOKS like the axis of the shafts are not the same (see below).
http://s950.photobucket.com/albums/a...a.jpg&newest=1 Other than that, I am curious to see how ya'll elevate/score, I can't tell from the photo... Good luck this year! -624 |
#11
To go along with some of the other comments here...
Where the bumper zone is on your robot appears to be the weakest area in terms of structure, at least from what I can tell from these pictures. We build our drivetrains (among other things) in a very similar manner as you guys. We use 1/4" aluminum plates, and use round standoffs to hold them together. This is what you have done in your drive system, but above the drive system there does not appear to be any standoffs. Seeing as this is where the bumpers will be, and thus most of your interaction with other robots will be, are you concerned about bending in that area? Also, was that milled or waterjetted? If it was milled, I'd love to see some pictures of it in process if you have any. -Brando |
#12
I think that is a work of art.
Are you planning on using shims for attaching bumper? Your gonna have to do something to make those wheel bearings and screws legal. |
#13
well, wouldn't it make more sense to make it out of one part instead of having multiple parts that could break, and have to be made with close enough tolerances to fit together.
#14
I wouldn't worry about that too much, it has proven to be a light, yet robust way of creating a custom chassis to the parts our bots require. Four years running with this design, and no structural failures yet.
#15
In SOME things that is true, but a whole robot? If this frame got hit hard (which it will), there is a good chance that it would bend. You cant replace a bent part of a robot that is one giant piece. Unless you have infinite quantities of those plates! And besides, building the robot with good ol' nuts and bolts is fun!
| pic: Team 223 Chassis | jjjeski | Extra Discussion | 26 | 17-02-2010 23:53 |
| Pic: Team 935's nearly complete chassis | railerobotics | Robot Showcase | 44 | 20-02-2008 12:11 |
| pic: Team 1058 chassis | PVCMike | Extra Discussion | 3 | 30-01-2007 22:28 |
| pic: Team 27 2004 Chassis | CD47-Bot | Robot Showcase | 2 | 25-02-2004 23:29 |
| pic: Team 369 Chassis | CD47-Bot | Robot Showcase | 7 | 11-02-2004 19:58 |
