Go to Post Remember that it's not what is on the outside of the shirt that matters, it's what is on the inside. - dtengineering [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 17-02-2010, 22:43
unobtainium-42's Avatar
unobtainium-42 unobtainium-42 is offline
Team President
AKA: Eric Eaton
FRC #0670 (Homestead Robotics Team)
unobtainium-42 is an unknown quantity at this point
CAN user code fails to load
When I use #include "../CANJaguar/CANJaguar.h" and try to use the CANJaguar class the code crashes:
task 0x1319f60 (wtxC5124tmp) deleted: errno=196709 (0x30065) status=45106 (0xb032)
-> FPGA Hardware GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E
FPGA Software GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E
FPGA Hardware Version: 2010
FPGA Software Version: 2010
FPGA Hardware Revision: 1.3.0
FPGA Software Revision: 1.3.0
* Loading StartupDlls: FRC_BlackJagBridgePlugin
FRC_BlackJagBridgePlugin was compiled from SVN revision 10
task 0x1d6ae78 (t2) deleted: errno=0 (0) status=0 (0)
* Loading StartupDlls: FRC_UserProgram
NI-VISA Server 4.5 started successfully.
task 0xe416d0 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
Warning: module 0x131b170 (FRC_UserProgram.out) holds reference to undefined symbol _
ZN9CANJaguarD1Ev.
ZN9CANJaguarC1EhNS_11ControlModeE.
ZN9CANJaguar3SetEf.
(unloading partially loaded module FRC_UserProgram.out)
...FRC_UserProgram failed to load.
Welcome to LabVIEW Real-Time 8.6.1f2
The code compiles with no warnings or errors. I am not using 2CAN, I am using a custom serial connector to the Black jaguar. BDC-COMM works. I updated the firmware and set their board IDs.
Unread 17-02-2010, 23:14
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: CAN user code fails to load
It looks like the actual CANJaguar class isn't in your project. You added the cpp files to your project as well as the h files, right?
EDIT: Your problem is you put the CANJaguar code as a separate project. The actual code isn't being built with your user code. If you put a folder reference in your project the the CANJaguar folder it should work, or you could just copy the files directly into your project (that's what we do)
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 17-02-2010, 23:37
Team President
AKA: Eric Eaton
I put the files in the project, and all of a sudden these errors popped up:
Build Started in Project 'Breakaway':   2010-02-17 20:35:30
Generation of makefiles started.
Generation of makefiles finished (Elapsed Time: 00:00).
Platform: Wind River VxWorks 6.3
Command: make --no-print-directory BUILD_SPEC=PPC603gnu DEBUG_MODE=1 TRACE=1 clean all
Working Directory: D:/Eric/Documents/Projects/Robotics/workspace2/Breakaway/PPC603gnu
make: removing targets and objects of D:/Eric/Documents/Projects/Robotics/workspace2/Breakaway/PPC603gnu
if [ -d "Breakaway" ]; then cd "Breakaway"; rm -rf Debug; fi
if [ -d "Breakaway_partialImage" ]; then cd "Breakaway_partialImage"; rm -rf Debug; fi
if [ ! -d "`dirname "Breakaway_partialImage/Debug/Objects/Breakaway/CANJaguar.o"`" ]; then mkdir -p "`dirname "Breakaway_partialImage/Debug/Objects/Breakaway/CANJaguar.o"`"; fi;echo "building Breakaway_partialImage/Debug/Objects/Breakaway/CANJaguar.o"; ccppc -g -mcpu=603 -mstrict-align -mno-implicit-fp -mlongcall -ansi -Wall  -MD -MP -mlongcall  -IC:/WindRiver/vxworks-6.3/target/h -I../CANJaguar -IC:/WindRiver/vxworks-6.3/target/h/WPILib -IC:/WindRiver/vxworks-6.3/target/h/wrn/coreip   -DCPU=PPC603 -DTOOL_FAMILY=gnu -DTOOL=gnu -D_WRS_KERNEL    -o "Breakaway_partialImage/Debug/Objects/Breakaway/CANJaguar.o" -c "D:/Eric/Documents/Projects/Robotics/workspace2/Breakaway/CANJaguar.cpp"
In file included from D:/Eric/Documents/Projects/Robotics/workspace2/Breakaway/CANJaguar.cpp:3:
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:13: error: `tNIRIO_i32' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:16: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:19: error: `tRioStatusCode' does not name a type
There's a hundred similar lines...
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:287: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:293: error: expected `,' or `...' before "status"
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:294: error: ISO C++ forbids declaration of `tRioStatusCode' with no type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h: In function `bool rioStatusIsFatal(int)':
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:295: error: `status' undeclared (first use this function)
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:295: error: (Each undeclared identifier is reported only once for each function it appears in.)
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h: At global scope:
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:298: error: expected `,' or `...' before "status"
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:299: error: ISO C++ forbids declaration of `tRioStatusCode' with no type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h: In function `bool rioStatusIsNotFatal(int)':
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:300: error: `status' undeclared (first use this function)
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:306: error: expected `,' or `...' before "newStatus"
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:307: error: ISO C++ forbids declaration of `tRioStatusCode' with no type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h: In function `T& rioSetStatus(T&, int)':
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:308: error: `newStatus' undeclared (first use this function)
D:/Eric/Documents/Projects/Robotics/workspace2/Breakaway/CANJaguar.cpp: In member function `void CANJaguar::InitJaguar()':
D:/Eric/Documents/Projects/Robotics/workspace2/Breakaway/CANJaguar.cpp:31: error: `kRIOStatusVersionMismatch' undeclared (first use this function)
C:\WindRiver\vxworks-6.3\host\x86-win32\bin\make.exe: *** [Breakaway_partialImage/Debug/Objects/Breakaway/CANJaguar.o] Error 1
Build Failed in Project 'Breakaway' (Process Exit Value was 2):   2010-02-17 20:35:32   (Elapsed Time: 00:02)
Did I forget to include something? More importantly, why didn't this happen before?
Unread 18-02-2010, 17:47
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
These are well known errors. You need to include the following line into your CANJaguar.cpp code just above the #include "ChipObject/NiRioStatus.h"
#include "ChipObject/NiRio.h"
This will make the compile errors go away.
HTH,
Mike
Unread 18-02-2010, 19:40
Team President
AKA: Eric Eaton
That worked, thanks.
The robot reports this runtime error via console:
>>>>ERROR: status == -52010 (0xFFFF34D6) in sendMessage() in D:/Eric/Documents/Projects/Robotics/workspace2/Breakaway/CANJaguar.cpp at line 176
And via DS:
<Code>-52010 ERROR: status == -52010 (0xFFFF34D6) in sendMessage() in D:/Eric/Documents/Projects/Robotics/workspace2/Breakaway/CANJaguar.cpp at line 176
NI Platform Services: The requested resource must be initialized before use.
All I do is instantiate CANJaguar objects, like the example. Is there any document I should be reading while doing this? If the error's well known, how was I supposed to find out?
Unread 19-02-2010, 00:28
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
You need something in your code similar to
CANJaguar* Motor = new CANJaguar(3,CANJaguar::kPercentVoltage);
The 3 is the CANBus id, and the second arguement is a enum for the type of controls. Put this in your initialization. Of course change the name motor to the nameof your variables.
If you have this, post snipets of your code. Also make sure you set CAN IDs to each jaguar. If any 2 share a ID, the bus gets confused. I know you said you set them, but I have had my jaguars reset their IDs for no apparent reason.
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
Robot code won't load RevusHarkings C/C++ 3 18-02-2010 15:19
Downloading Default Code Fails 1951-44U Java 3 30-01-2010 11:55
Code runs only once, fails on reset roknjohn Programming 7 21-02-2005 20:24
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Can we load 2004 code? colt527 Programming 5 15-02-2005 19:48
