Go to Post We had an over all losing record this year. When I look at kid's faces, they don't give a rip about that. I see excitement about the next event and talking about improvements for next year. Winning is nice, but that is not the reason I do what I do. - wilsonmw04 [more]
Unread 15-01-2008, 14:42
jjjeski jjjeski is offline
FRC #0223
jjjeski will become famous soon enough
Re: pic: Team 223 Chassis
Also, the chassis is not complete in the picture. We're still working on it now.
Unread 15-01-2008, 15:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Why is the chassis cut on an angle at the ends? There are no obstacles to clear and I'd think you wouldn't want to be riding up over other robots.
Unread 15-01-2008, 16:01
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Clearly you've never been pushed back far enough to be stuck on an edge of your frame and whatever else is lifting the other end of the robot. The cutback ends allow the wheels to be in contact at any angle. But, with mandatory bumpers now, that point is moot.
Bengineer
Unread 15-01-2008, 16:41
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
From what I can tell from the photo I would be worried that this design (as pictured) would violate <R19> (no wedge bots) thus making it illegal.
<R19> "Wedge” ROBOTS are not be permitted. ROBOTS shall be designed so that interaction with opposing ROBOTS results in pushing rather than tipping or lifting. Neither offensive nor defensive wedges are allowed. All parts of a ROBOT between 0 and 8.5 inches from the ground (the top of the BUMPER ZONE) that are used to push against or interact with an opposing ROBOT must be within 10 degrees of vertical. Devices deployed outside the ROBOT footprint should be designed to avoid wedging. If a mechanism or an appendage (e.g. a harvester for retrieving GAME PIECES) becomes a wedge that interferes with other ROBOTS, penalties, disabling, or disqualification can occur depending on the severity of the infraction.
Note that nowhere in the rule is there any mention of which way the wedge is oriented. Now your bumpers may fix the issue but since you are only required to have the bumpers on 2/3 of your robot it may or may not.
Unread 15-01-2008, 17:28
CraigHickman
Posts: n/a
Wow... cut them some slack.
I'm sure a team that's been around that long knows what CG is, and I bet that's only 50-60 pounds of what's going on the robot, you don't know how the rest is distributed. For all you know that could be all 1/16" wall and be much lighter than you are guessing.
114 of all people should know that being tall doesn't necessarily mean poor CG.
It looks to be 1/8th. However, I don't know for sure, which is why I asked the team if they had done CG calculations. And we very well know that being tall doesn't mean bad CG; our 07 bot was 11 feet tall, and could tip to 60 degrees and still stand up.
This drive base looks very solid. Think the poster could take a screenie with Inventor's CG icon in it, maybe a few views slapped into a post could really clear it up for all of us.
Unread 15-01-2008, 20:23
in between teams
AKA: Luke Van Oort
It is 1/16". That is 80/20 Quickframe (or similar); you can tell by the little black connectors in the corners. I have no idea what the structure is for, but it should be pretty darn light.
Team 1219: 2009 - Mentor
Unread 15-01-2008, 21:30
IbleedPink233's Avatar
IbleedPink233 IbleedPink233 is offline
FRC #0233 (The Pink Team)
IbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to behold
Originally Posted by Kyle Love View Post
Guys...its the Pink Team, they can make it work.
Thanks for the confidence, but no it is definitely not us.
Besides, when have you known the Pink Team to release genuine information about our robot before it is shipped? Never. Although, there may or may not be some revealing or pointless teasers coming some time in the near of distant future - so hang on to your seats.
Unread 16-01-2008, 13:29
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
What the heck is this...i am sry but did u guys think of the game or just did it...??? It is too top heavy.
Unread 22-01-2008, 02:06
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Originally Posted by Otaku View Post
angled frame + back or side heavy + trackball = oh god, this won't end well.
Unless you weigh down the opposite side. Which you might not be able to weigh down enough if you can't make weight normally. If you can, pull a Quixilver and ziptie some rebar to your robot. It seemed to work alright for them...
REBAR!!!!
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 17-02-2010, 23:51
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
i dont think that cg would affect them in a normal game, going over the hump..... that changes things a lot.
Unread 17-02-2010, 23:53
*Ahem*
This picture is from 2 seasons ago
Please look before you post next time.
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
This thread is from 2008......
pic: Team 1058 chassis PVCMike Extra Discussion 3 30-01-2007 22:28
pic: Team 1058 chassis II PVCMike Extra Discussion 10 29-01-2007 23:53
Hats off to team 223 M. Hicken Thanks and/or Congrats 1 08-03-2004 17:42
pic: Team 27 2004 Chassis CD47-Bot Robot Showcase 2 25-02-2004 23:29
pic: Team 369 Chassis CD47-Bot Robot Showcase 7 11-02-2004 19:58
