Go to Post Because nothing says safety like carrying a 150lb robot across a field covered in golf balls. - Kevin Sevcik [more]
Unread 16-02-2010, 23:54
chmconkling's Avatar
chmconkling chmconkling is offline
Jack of all groups. Master at most.
AKA: chris
FRC #2363 (Triple Helix)
chmconkling is an unknown quantity at this point
Talking anybody know where to get some quick exaust valves or dump valves
they need to have a 1.0 cv and 1/4 or 1/8
Unread 16-02-2010, 23:59
sbrumund sbrumund is offline
FRC #2115 (M cubed)
sbrumund is an unknown quantity at this point
Re: anybody know where to get some quick exaust valves or dump valves
I beleive you are limited to a vlave with 1/8" ports like the valve provided in the kit of parts so here will not be any quick exhaust valves
Unread 17-02-2010, 00:10
AKA: chris
i don't want a solenoid valve i want a exhaust valve that mounts directly to the cylinder and releases the air into the atmosphere and not back through the tubes and out of the valve
Unread 17-02-2010, 01:15
Any reason you can't just leave it open?
Unread 17-02-2010, 01:33
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Any valve on the robot must meet the .32 CV requirement per this Q&A:
http://forums.usfirst.org/showthread.php?t=14463
As Eric said, you can probably just vent that end of the cylinder without a valve
Unread 17-02-2010, 07:37
terryo terryo is offline
AKA: Terry O'Brien
FRC #1784 (Litchbots)
terryo is an unknown quantity at this point
1784 and 1086 asked if dump valves / shuttle valves or quick exhaust valves were permitted in Q&A. Answer was no. See this post as well:
http://forums.usfirst.org/showthread.php?t=14516
Unread 17-02-2010, 08:25
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Like they said a release valve is not necessary. Just leave the port open and let the air vent straight out the port. There is no rule requiring a fitting to be installed on a cylinder.
Unread 17-02-2010, 08:58
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Of course, if you actually need to control the cylinder more than once...you need to have the "open" port plumbed to move the cylinder in the other direction...
I know a very excellent team used these before:
http://www.clippard.com/store/displa...p?sku=JEV-F2F2
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 17-02-2010, 10:01
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
You should put a fitting on with a filter to prevent dirt from getting into the cylinder. That's my opinion but one from experience.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 17-02-2010, 10:51
Racer26 Racer26 is offline
Alternately, gravity can do this for you.
Unread 17-02-2010, 21:27
AKA: chris
actually no a SOLENOID VALVE must have a cv of .32 any other "valve" can anything it wants
Unread 17-02-2010, 21:37
DonRotolo's Avatar
Back to humble
FRC #0832
Um, best you read <R72> again, more carefully. Especially the part about "pneumatic system items specifically permitted on 2010 FRC ROBOTS include the following items.", since your item is NOT listed and thus not allowed.
But, you feel free to interpret it any way you like, and good luck at inspection!
Unread 17-02-2010, 21:59
Electrical Engineer
Rookie Year: 1995
Actually, no. To reinforce Don's post, "anything else" is not allowed.
Mike Betts
As easy as 355/113...
Unread 17-02-2010, 22:33
Before you read <R72>, read <R71>.
And then pay special attention to <R72-C>, second sentence. What you're looking for falls into the category of "such valves". As such, it cannot have a Cv of more than 0.32 or a port diameter of more than 1/8".
Disagree with the rules or our interpretation of the rules? Submit a question to the GDC via the official Q&A. Should they rule that such a valve is in fact legal, then please print out the ruling and bring it to competition. The inspectors may or may not get the memo before the event. If you don't do this, and then you show up with an illegal configuration, expect to sit out until it is fixed.
Unread 17-02-2010, 23:57
AKA: chris
<R72> In addition to the items included in the KOP, pneumatic system items specifically permitted on 2010 FRC ROBOTS include the following items. All included items must be “off the shelf” pneumatic devices rated by their manufacturers for pressure of at least 125psi, and used in their original, unaltered condition (except as required for assembly with other components).
A. One or two additional Clippard air storage tanks (Clippard Part Number AVT-32-16), equivalent to those provided in the kit. This means that up to four, and no more, Clippard air storage tanks can be used on the ROBOT.
B. Pneumatic pressure vent plug valves functionally equivalent to those provided in the KOP (Parker Part Number PV609-2).
C. Solenoid valves. All such valves must have a maximum ⅛” NPT port diameter, and a maximum Cv of 0.32 (if non-KOP valves are used, the team will be required to provide part documentation validating that the valves meet these constraints). Solenoid valves that are rated for a maximum pressure that is less than 125psi rating mandated above are permitted, however if employed, an additional pressure relief valve must be added to the low pressure side of the main regulator. The additional relief valve must be set to a lower pressure than the maximum pressure rating for the solenoid valve.
D. In addition to the pneumatic cylinders provided in the KOP and the “free” pneumatic cylinders available for order through the Free Pneumatic Components Order Form, additional air cylinders or rotary actuators may be used. Cylinders may be of any configuration, and may be of any size up to a maximum of 24-inch stroke and 2-inch diameter.
E. Additional 0.160” inch inside diameter pneumatic tubing functionally equivalent to that provided in the KOP, with the pressure rating clearly factory-printed on the exterior of the tubing (note: alternate tubing colors are acceptable).
F. Pressure transducers, pressure gauges, and connecting fittings.
G. Pressure regulators with a maximum bypass pressure of no more than 60psi.
H. For the purposes of the FIRST competition, a device that creates a vacuum is not considered to be a pneumatic device and are not subject to the pneumatic rules (although they must still satisfy all other appropriate rules). These include, but are not limited to, venturi-type vacuum generators and off-the-shelf vacuum devices (as long as they are powered by provided or permitted motors).
I. For the purposes of the FIRST competition, closed-loop COTS pneumatic (gas) shocks are not considered pneumatic devices, and are not subject to the pneumatic rules (although they must still satisfy all other appropriate rules).
J. For the purposes of the FIRST competition, air-filled (pneumatic) wheels are not considered pneumatic devices, and are not subject to the pneumatic rules (although they must still satisfy all other appropriate rules).
The rule only applies to soleniod valves
Anybody having any luck finding pneumatic valves??!?!? chmconkling Pneumatics 16 04-02-2010 17:34
Anybody hvaing any luck ordering the 2010 FESTO Valves? chmconkling Pneumatics 4 24-01-2010 19:52
Leaky Valves Mark Deutsch Pneumatics 9 16-02-2007 15:07
where are double solenoid valves placed Reaper40 Pneumatics 5 28-01-2007 15:54
Does anybody know where to find blank DVD case Kyle Fenton 3D Animation and Competition 2 18-01-2002 01:04
