Go to Post From what I've seen in FIRST, teams that copy generally always learn something from it, and if they don't, the copy they produce is of much lower quality than the original. - TheOtherGuy [more]
Unread 18-02-2010, 00:47
Twisted eric's Avatar
Twisted eric Twisted eric is offline
FRC #0581
Twisted eric is an unknown quantity at this point
Limit Switch
In java I'm trying to code a limit switch to my single motor called hunt
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Watchdog;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Jaguar;
public class Pup extends SimpleRobot {
    private static final long TIME_DELAY = 1000; // in milliseconds
    RobotDrive drive = new RobotDrive(1, 2);
    Joystick leftstick = new Joystick(1);
    Joystick rightstick = new Joystick(2);
    Jaguar hunt = new Jaguar(4);
    Joystick spot = new Joystick(4);
    Joystick kicker = new Joystick(3);
    Watchdog fenrir = Watchdog.getInstance();
    Compressor fluffy = new Compressor(1, 1);
    void setUpRobot() {
        fluffy.start();
        fenrir.feed();
    public void autonomous() {
        setUpRobot();
        fenrir.setEnabled(false);
        while (true && isAutonomous() && isEnabled()) {
            drive.drive(1.0, 0.0);  // drive 100% fwd 0% turn
    public void operatorControl() {
        setUpRobot();
        while (true && isOperatorControl() && isEnabled()) // loop until change
            drive.tankDrive(leftstick, rightstick);
            hunt.set(kicker.getY());
            Timer.delay(0.005);
            fenrir.feed();
but i want it so that when it hits it, it will not go that way
limit switch solomason519 Programming 9 09-02-2010 08:50
Limit Switch Problem Boydean Programming 3 13-02-2008 16:32
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
limit switch wedellm Electrical 4 16-02-2007 13:01
