Go to Post Thinking (or the lack of it) will be our downfall. - sirbleedsalot [more]
Unread 18-02-2010, 07:15
Re: Camera Issues (we have tried practically everything!)
Just checking about the location.
The Vision Processing VI contains a loop that either sleeps or gets and processes an image. That decision is made based on a global. If you set that global you can control the vision processing. The place the global is currently set is in Robot Main.
Note this processing is independent of the vision back to the PC. There is a similar button beneath the dashboard that will enable and disable the dashboard images. Since those are not processed by the cRIO, the overhead to retransmit is really small by comparison.
Greg McKaskle
1726 - practically done! TheOtherGuy Robot Showcase 10 19-02-2008 16:14
Camera Oversaturation Issues? 114Klutz Programming 11 19-04-2007 17:47
Camera Issues RedOctober45 Programming 5 08-02-2007 15:59
Camera issues Todd Programming 0 16-02-2005 19:06
