Our team is having the same problem. We installed LabVIEW update 2.1 and Driver-station update 1.1 on the Classmate, updated the cRIO image to v20. We can only connect with the driver station while LabVIEW is not loaded (we cannot run the code in a real time connection). It still displays "No Robot Code".
![]() Any ideas would be lovely. ![]() |
Re: No Robot Code
What messages or response do you get when you push the "Run" button on Robot Main.vi?
Re: No Robot Code
When I attempt to start the Driver Station, the connection between the cRIO and LabVIEW times out and stops entirely. Then the Driver Station connects, and still says, "No Robot Code". |
Re: No Robot Code
Re: No Robot Code
I can try this, but I believe LabVIEW wouldn't connect at all with the Driver Station already running (and connected).
Re: No Robot Code
You have Exited the Driver Station in the Driver users account and are running it only in the Developer account aren't you?
Not switching back to the Driver account to run the Driver Station. |
#7
Re: No Robot Code
Yes, I hold SHIFT while windows comes up so I login only the Developer account, and run the Driver Station while in Developer.
#8
Re: No Robot Code
Sounds weirdly like only one app can use the network connection at a time.
You can also try turning off the Classmate wireless while you are trying this, so we know it isn't port confusion. Have you changed the Classmate much, if at all, from it's original condition by installing third-party software? |
#9
Re: No Robot Code
Got it working. I created a new blank cRIO FRC Project with all the updates installed, and magically everything works.
#11
Re: No Robot Code
Might have been a mix of old version code then.
Good news. |
#12
Re: No Robot Code
Actually, the old code from before I re-imaged the Classmate worked perfectly now that everything was properly installed.
| No Robot Code After downloading Code | tutkows1 | FRC Control System | 2 | 08-02-2010 00:51 |
| No Robot Code | eaglesfan10 | C/C++ | 6 | 03-02-2010 22:34 |
| Compressor Code causes No Robot Code Error | sircedric4 | C/C++ | 25 | 03-02-2010 10:13 |
| No Robot Code | mlim | NI LabVIEW | 10 | 21-01-2010 17:33 |
| Robot Code? | leftylink | Programming | 0 | 18-02-2008 14:34 |
