#15
Re: cRIO not turning on!!!
Thanks for that last word. Yes, definitely check the 24 VDC supply first then even after opening the case check for continuity on F2. Ours was open and the aluminum pigtail shaving obviously resting between the fuse and the serial port shell inside.
| cRIO Not Working?!? | JohnFogarty | Electrical | 6 | 01-17-2010 03:53 PM |
| cRIO Not Working?!? | JohnFogarty | Control System | 2 | 01-17-2010 08:33 AM |
| cRio not working...? | Jack Gillespie | Programming | 22 | 02-13-2009 01:07 PM |
| CRio Not Responding | Shadow_Cat | NI LabVIEW | 7 | 02-13-2009 08:12 AM |
| 1 joystick controls not turning properly | andrew_4_life | Programming | 4 | 03-28-2008 01:22 AM |
