Go to Post Got Valentine's day present from wife before leaving for work. Non-contact IR thermometer, two unscuffed pairs of safety glasses for competitions, bag of York peppermint patties. She understands me. - Greg Young [more]
Unread 18-02-2010, 00:32
Al's Annual Inspect before you ship! and What To Expect at Your First Event thread.
OK readers.
This is where we start to list the things teams should not forget to check prior to ship.
Please read the bumper rules, again! Bumpers are at a different height this year, are non-moving and must be able to display two colors only Red and Blue.
Bumpers must have the Team Numbers in four inch high by 3/4" stroke contrasting colors on four sides of the robot.
No motors not provided in the KOP except those listed in the rules.
Make sure all mechanisms are safe to protect your students and those who are likely to be near the robot anytime it is out of the crate.
Weigh the robot and check the size. Then check your scale and your tape measure and repeat first sentence. It is easy to skin an ounce but impossible to lose thirty pounds. I can do it but you won't like it.
The FRAME PERIMETER is defined and nothing can extend beyond the perimeter outside of the bumper zone. Bolt heads, fasteners and axle shafts are include in the must not extend list.
Please check the First website for answers to the Q&A and the biweekly updates. We (your inspectors) check often and read all of it. We are up to Rev I on Section 8 and team update #11 came out last night.
Be sure you have downloaded and installed the latest software and firmware. If you are using CAN that means the firmware in your Jaguars needs to be the latest version. You will be asked to demonstrate the version numbers during inspection.
Please download the BOM template and use it to list your robot's materials and parts. Do it now while you still have the robot in front of you. It is part of the inspection and you will not be complete without it.
If you are using pneumatics (I am guessing many more teams than ever before will be this season) there is a list of minimum requirements for your system. Pressure relief valve, vent, regulator, two gauges and a pressure switch are all required items. The pressure switch is connected to the CRio, not the compressor. Operation of the system will be checked during inspections.
If you are using any parts that are not known by the inspectors, be ready to show spec sheets to prove they meet the minimums listed in the rules.
That is enough for now, I am sure others will soon tack on their choices. If you have any questions, ask.
Inspectors are not in place to keep you from playing. We are there to help you play, within the rules and safely. When you have a problem, let them try to help you or find someone who can.
Read the manual, wear your safety glasses, have fun!
Unread 18-02-2010, 01:40
Trying to Help Trying to Help is offline
FRC #1729 (Monadnock 4-H Robotics)
Trying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud of
Re: Al's Annual Inspect before you ship! thread.
Thanks for doing this list Al!
I'm sure it will help many teams in the last few days of build prepare for a happier unpacking at their competition.
Trying to Help
Unread 18-02-2010, 08:44
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Al, great reminders
Are they going to post the inspection checklist here before ship?
http://www.usfirst.org/roboticsprogr...nt.aspx?id=452
Kinda seems pointless to post it up there after ship (or at least makes the Thursday inspections MUCH slower).
I hit post too fast...
Had one question, from the definition of FRAME PERIMETER:
Note: to permit a simplified definition of the FRAME PERIMETER and
encourage a tight, robust connection between the BUMPERS and the FRAME PERIMETER, minor
protrusions such as bolt heads, fastener ends, rivets, etc are excluded from the determination of the
FRAME PERIMETER.
(bolding mine)
Is this the same:
Al, if I read your post, you are saying bolt heads cannot extend outside the frame perimeter, but I thought thats what the team update said was specifically allowed?
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 18-02-2010, 09:24
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Bolt heads are allowed outside the FRAME PERIMETER only within the BUMPER ZONE and nowhere else.
___________________
- Tennyson, Ulysses
Unread 18-02-2010, 09:34
GaryVoshol's Avatar
Cogito ergo arbitro
Kim, we went round and round on this here: http://www.chiefdelphi.com/forums/sh...ad.php?t=81042
As it stands now, from my understanding of Team Updates 6 and 7, you are allowed minor protrusions in your FRAME PERIMETER, and they do not count in the definition of it. But remember that FRAME PERIMETER is defined to be in the BUMPER ZONE.
Protrusions that extend beyond the vertical projection of your FRAME PERIMETER outside the BUMPER ZONE are disallowed except for the exclusions in <G30>. Bolts, axle ends, etc are not allowable exclusions.
So the way it sits is a bolt that holds your frame together within the BUMPER ZONE is OK. A bolt that holds your lower frame together or a bearing that holds your axle, is not excluded. The only effective way to get around this is to make sure your frame dimensions in the BUMPER ZONE are the largest dimensions of your robot.
(since 2004)
Unread 18-02-2010, 09:38
Al, great reminders
We are trying for today or tomorrow at the latest.
Unread 18-02-2010, 09:41
Ahhh ok we are on the same page I was thinking he meant that bolt heads in the bumper zone werent allowed... I think I read his item too fast to catch the "outside the bumper zone" as a qualifier... Im tired and Im not even in Rochester!! lol.
~kim~
Unread 18-02-2010, 09:45
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Just a few to add to Al's excellent post.
1) Remove all sharp edges from bot. I don't like to see any blood....especially mine
2) Check all the wiring. You don't want to go to your first regional and find out you used the wrong wire gage
3) ONLY your team number is allowed on the bumpers.
4) Only one motor per speed control.
Good luck this year.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 18-02-2010, 09:47
OK,
Time for another round. (anyone can add to this list)
The robot signal light (the big orange light in the white box) must be mounted and wired on the robot at the time of inspection.
The wireless adapter must be powered from the dedicated power connector on the Power Distribution Board (the PD). You will loose control without this critical power supply connection.
For Rookies and all other interested parties. bring the remainder of your 2010 KOP to the event. You might need something from that box of parts or you may need to trade for something. Be sure to check around your shop or build area to pick up everything that belongs back the kit. If you bring the KOP and have forgotten what I said at the top of this post, then all you have to do is reach in, take out the RSL and add it to your robot.
Unread 18-02-2010, 09:54
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Ok, so this causes some problems for us... The way we are set up right now, i guess we break this rule as bolt heads extrude. If the bumper wood is already 3/4" thick, i dont see why first wouldnt allow for .25" extrusions max for bolt heads... Anyway, as it is now, our bumpers have an large, sturdy L bracket that is attached to the bumper perminantly and taps into our frame to attach there. I know that the bumper must rest fully along the frame also. So could we just attach the L bracket instead permentally to the robot (extending out of the frame 1/4 inches, making it a permiant fixture) and then just mount the bumpers onto that? It isnt as structural and is a bit harder to remove and adds weight to our robot, but would this be an acceptable solution?
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 18-02-2010, 10:03
GaryVoshol's Avatar
Cogito ergo arbitro
Rick, hopefully you have enough space and weight to add a solid strip of something around your FRAME PERIMETER to extend it beyond all those pesky protrusions.
It can't be something added to the BUMPER, because BUMPERS are limited to being built with plywood, pool noodles, cloth and fasteners.
(since 2004)
Unread 18-02-2010, 10:22
Rick,
L brackets that are used to mount the bumpers on your robot are part of the robot for weight and size under certain circumstances. They are not part of the bumper. L brackets that are part of the bumper (as shown in the bumper diagram) used to secure the fabric are considered part of the bumper and are excluded from robot weight.
<R07> Teams are required to use BUMPERS on their ROBOTS. BUMPERS have several advantages, such as reducing damage to ROBOTS when they contact other ROBOTS or ARENA elements, and being excluded from the calculation of ROBOT weight and volume constraints specified in Rule <R10>.
G. Each set of BUMPERS (including any fasteners and/or structures that attach them to the ROBOT) must weigh no more than 20 pounds.
Please review the rules R07 and R10 and especially ask if you do not understand the definition of FRAME PERIMETER as it is written in the Rev I of the robot rules.
Unread 18-02-2010, 10:31
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
So, if we have bolt heads in the bumper zone and bolt heads outside of the bumper zone that are in the same vertical plane the lower ones are not legal even though the max robot size is not exceeded?
Bruce
Unread 18-02-2010, 10:49
That's the most straightforward interpretation of the rule, yes.
Unread 18-02-2010, 11:33
Bruceb's Avatar
Seems kind of rediculous to me. Woudln't the bolt heads define the robot perimeter?
Bruce
[BB]: Before you pick your second event Kristian Calhoun General Forum 0 18-10-2009 10:55
**FIRST EMAIL**/"Your Regional Event; What to Expect" Teleconference - Monday, Februa Mark McLeod FIRST E-Mail Blast Archive 0 20-02-2008 17:42
**FIRST EMAIL**/What to Expect at Your Regional Event Mark McLeod FIRST E-Mail Blast Archive 1 26-02-2007 19:10
What does your team do before FIRST season? 65_Xero_Huskie Team Organization 17 29-11-2006 21:31
its a day before ship.....do you know were your robots at? xzvrw2 Chit-Chat 5 20-02-2006 16:42
