Re: cRIO smoke
The red Analog Breakout is where the smoke came from when we reversed our battery leads this week... |
Re: cRIO smoke
Heh. we toasted a 2k9 analog breakout too... student wired the cable into the wago backwards. replaced with 2010 breakout after fixing the wiring, all is well. No smoke from ours though.
Re: cRIO smoke
Swapping the battery leads will likely destroy the following: 2009 Analog Breakout Victor Jaguar |
Re: cRIO smoke
I agree with the others here,
during inspection at BMR last year, one of our electricians (not me!) accidently hooked the battery leads backwards to the PDB putting voltage backwards through the whole system, Surprisingly, only the analog breakout fried! the cRio is stilll functioning like a charm, didnt even fry the cRio module. if the LED on the analog breakout is not lit, then its done for. check the IC on the top right hand corner, thats where most of them tend to fry! |
Re: cRIO smoke
The smoke came from the module that the sidecar is plugged into. Our anolog breakouts are blue and LED's are lit.
| Battery Smoke | Al Skierkiewicz | Electrical | 27 | 24-05-2007 10:12 |
| anyother robots smoke up? | 65_Xero_Huskie | General Forum | 40 | 01-11-2006 19:37 |
| pic: Magic Smoke | Mark McLeod | Extra Discussion | 15 | 04-05-2006 15:57 |
| Making a smoke machine forcefully blast out the smoke. | sanddrag | Technical Discussion | 16 | 18-12-2005 23:46 |
| The Magic Smoke... | BlueOrion | Motors | 17 | 30-03-2004 07:47 |
