Go to Post Legos rock! - Kyle Love [more]
Unread 18-02-2010, 11:55
May_Walter's Avatar
May_Walter May_Walter is offline
Artemis #3083
FRC #3083 (Artemis)
May_Walter is an unknown quantity at this point
A question about the robot's light
Hi everyone,
We looked over the manual, but it does not specify the rules about the light we got in the kit. We don't know exactly how and where we need to connect it. What are the specific rules about it?
Thanks a lot,
team Artemis
#3083
Team ARTEMIS - #3083 - The Sky Isn't The Limit Anymore!
2011- FRC Team Captain and Coach, FLL mentor & Ref. Semi-Finalists, Motorola Quality Award, Star of the Day.
2010 - FRC Team Captain and Coach, Engineering Inspiration Award, UL Industrial Safety Award
2009 - Coach, Judges Award, Finalists w/ 3075 & 1690
Unread 18-02-2010, 11:59
J_Beth J_Beth is offline
AKA: Justin Beth
FRC #0935 (RaileRobotics)
J_Beth will become famous soon enoughJ_Beth will become famous soon enough
Re: A question about the robot's light
You should take a look at the power distribution diagram, it helped us wire ours. We took a PWM and cut off the side with the male connector, and striped those ends and wired like the diagram showed us.
EDIT:
Here is a link to the diagram.
http://www.usfirst.org/uploadedFiles...ution_RevA.pdf
You will need to cut a piece of extra PWM (we used a piece of white because that's not used here) to make the jump from the positive wire to the slot on the far side. I wish that i had the light here so that i could see the labels and tell you what goes where but alas, i don't have one. The best way for me to discribe it would be that you put your negative PWM (black) in the center of the light, and the positive(red 0 goes on one of the outsides, with a small wire running from that slot to the slot on the other side.
Hope this helps, if someone that has access to a light could post what the labels are that would probably help a lot.
"I Wanna Be A Robot Maker!!!!"
Unread 18-02-2010, 12:06
Electrical Engineer
Rookie Year: 1995
Originally Posted by May_Walter View Post
Hi everyone,
Thanks a lot,
team Artemis
#3083
May,
<R59> is the rule that applies to the light. Also, as noted by Justin above, the Power Distribution Diagram is a good read...
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 18-02-2010, 12:18
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
Hi again,
Thanks for the information, but we would like to know if we can place the light inside the robot, in such a way that the light is visible from the front of the robot through a hole in the semi-transparent cover. The light is going to be inside of the cover and won't stick out of it.
Thanks again,
team Artemis
#3083
Unread 18-02-2010, 12:35
Electrical Engineer
Rookie Year: 1995
Hi again,
Thanks again,
team Artemis
#3083
May,
From <R59>:
It must be mounted on the ROBOT such that it is easily visible while standing three feet in front of the ROBOT in the NORMAL CONFIGURATION.
Mike
Mike Betts
Unread 18-02-2010, 12:44
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
We plan that it will be visible from the front as the rule say, but we want to make sure that it is ok that the light will be completely inside the cover and visible through a hole in the front.
thanks again,
team artemis
#3083
Unread 18-02-2010, 12:49
May,
Field personnel will have a hard time trying to search for your RSL through a hole in the front. You should think about an alternative mount. Under certain conditions it flashed a different code than the flashing or ON that you expect to see. That flashing code tells the field people what the status of your robot is and whether it is ready to play.
Unread 18-02-2010, 12:57
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
Well, the cover of the robot is made out of blue semi-transparent plastic:
http://www.shaham1.co.il/var/7376/23...D7%9C%2011.jpg
and we expect the light to be visible through it as well.
Is that legal? Because we don't have a lot of options where we can place it.
Any ideas?
Unread 18-02-2010, 13:09
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Any ideas?
May,
The referees on the field are going to do everything they can to make sure that your robot will run during the match. One of the best indicators they have is the RSL.
Therefore, it is in your best interest to make it as visible as possible to the referees on the field. I do not know how opaque that material is to yellow light. As such I cannot answer if it is legal to use, and if it is legal then how useful it would be. If a referee does not see that your robot isn't ready then, more than likely, your robot will not run ... just something to consider.
___________________
- Tennyson, Ulysses
Unread 18-02-2010, 21:03
The RSL connector on the Digital Sidecar has only two pins. A PWM connector has three. You should have received a handful of two-wire cables with exactly the connector needed in the Kit of Parts. See the top of page 12 in the Kit of Parts Checklist.
Unread 18-02-2010, 23:20
AKA: Justin Beth
we only use two of the pins, the signal side of the female connector just sticks off the to the side, this has pass inspection every year, and it also provides us with the wire needed to make the jumper, without destroying another wire.
Unread 19-02-2010, 07:49
Justin,
"Every year" was just last year, and you got lucky. The connector that feeds the RSL has a locking device on it to keep it in place. You are provided the correct connector in the KOP. Using anything else to connect the RSL is a risk you do not need to take.
Unread 19-02-2010, 15:56
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Funny you mention that - we find that the 2-wire connector provided for the RSL (and pneumatic solenoids) has *just* too much plastic on it such that the locking mechanism for the RSL connector doesn't quite bite into the connector. We're using clear nail polish to provide adhesion (as opposed to super glue which would damage the plastic) - unless you've got a better suggestion?
NOTE: Our entire electronics mainboard is upside-down on the robot, so we've had to ensure the signal wires did not fall out for legacy devices (Spike / Victors) by providing our own tensioners for the wires. I cannot do the same thing for the RSL, however, which lead to the nail polish idea.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 20-02-2010, 01:26
Sorry to be misleading, Danny. I was in a funny mood with so little sleep and too much coffee. The connector on the DSC is meant to be used with a locking, white nylon connector. They are available from various sources but anything you use (PWM for instance) that will make the connection and not damage the board should be fine. I have seen the female pins from the PWM connectors (without the shell) just pushed on to the pins in the DSC and some heatshrink added to keep everything insulated. If you have some method to tie the wiring close to the surface that the board is mounted on, the tension on the wire should keep it in place. We mount our circuitry to perforated aluminum or perf stock. The holes are close together and a tywrap fits through them very easily. By tying down PWM cables in this fashion they cannot pull out without breaking the tie first.
question about the trailer haxor5354 Technical Discussion 1 09-02-2009 21:16
Question about the signal light Carmelulu` General Forum 2 05-02-2009 23:08
[OCCRA]: Question about a light MatthewArthur OCCRA Q&A 1 26-10-2005 22:21
turn on the light - question powercat Programming 12 22-02-2003 17:33
About the light that need to be seen from four side archiver 2000 3 23-06-2002 23:01
