Go to Post Karthik is afraid of the day he can't agasabapathy. - DesignComp [more]
Unread 17-02-2010, 22:16
PlaidPillagers's Avatar
PlaidPillagers PlaidPillagers is offline
FRC #2538 (Plaid Pillagers)
PlaidPillagers is an unknown quantity at this point
Re: Vision/AxisCamera2010.h
Originally Posted by BradAMiller View Post
I just rebuilt the library and posted it at:
http://first.wpi.edu/FRC/frccupdates.html
Please give it a try by installing the update and relinking. Let us know if it works.
Sorry for the confusion, I think we hit some limit in the library that's making the build process somewhat unpredictable.
Downloaded and installed. I rebuilt and downloaded my project, and these three lines still crash my code ("No robot code"):
		AxisCamera &camera = AxisCamera::GetInstance();
		camera.WriteResolution(AxisCameraParams::kResolution_160x120);
		camera.WriteBrightness(0);
Any further suggestions?
Team 2538
Plaid Pillagers
Morris, Minnesota
Rookie Year 2008
Unread 17-02-2010, 23:38
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
attach a console to it so you can watch the boot progress, what error is it giving?
Unread 17-02-2010, 23:43
Could you walk me through attaching a console?
Team 2538
Plaid Pillagers
Morris, Minnesota
Rookie Year 2008
Unread 17-02-2010, 23:50
Zme Zme is offline
FRC #2619
couple of ways to do it, one is flip the console out dip switch on the crio and attach to the serial port through a null modem to a computer that is running some console program (terminal.exe works or there is one built into windriver) second is to open up a net console, right click on the remote host in windriver (after connecting to it) then go to target tools and finally target console, a dialog box should pop up just hit ok,
i don't know how well the target console will work to watch the crio boot though, might connect to late, there is another way to do it but i don't know it so someone else will have to help you out with that
best of luck
Zme
Unread 18-02-2010, 00:31
misko misko is offline
FRC #0852
misko is an unknown quantity at this point
Thanks. Downloaded and installed. It fixes the unresolved problems with the previous version. I'm not having the issues plaid is having. Plaid, perhaps confirm that your crio is running the v20 code by checking the version under the drive station diagnostics tab?
Unread 18-02-2010, 10:51
I reinstalled all of the updates, and that helped. The camera code works now, and everything is considerably better.
There is a significant lag time on the camera to the DS display however. Is that normal?
Team 2538
Plaid Pillagers
Morris, Minnesota
Rookie Year 2008
Unread 18-02-2010, 11:31
Zme Zme is offline
FRC #2619
to a point yes, how much lag are you talking?
Unread 18-02-2010, 11:53
At its worst roughly from a second and a half to two seconds. In general though about half that.
Team 2538
Plaid Pillagers
Morris, Minnesota
Rookie Year 2008
Unread 18-02-2010, 12:00
Zme Zme is offline
FRC #2619
a half second i believe is the spec for the updated code for everything
try lowering the resolution, making sure the driverstation is not having its processing power strangled by windows power management, connect it via ethernet to the router, remove the live readout graphs from the dashboard if you have not already done so.
other than that i don't know what to tell you
good luck
Unread 19-02-2010, 08:27
All good advice, but from my testing, the charts on the dashboard do not add much load. I saw no difference with or without the charts.
Another thing that will help is to limit the FPS of the camera to what you need rather than telling it to go full 30fps.
Greg McKaskle
Unread 19-02-2010, 08:49
Zme Zme is offline
FRC #2619
we saw, (or thought we saw at least) a significant difference with and with out them, haven't run any tests though so can't say for sure
Unread 19-02-2010, 16:46
My camera code has gone back to crashing my robot.
Doing this will build and download:
AxisCamera *camera;
and this builds but does the same "no robot code" thing on the drivers station:
I reimaged our crio (v20) and redownloaded the code. No help. I reinstalled workbench update 4.3, remiaged the crio, and redownloaded code. Still nothing.
It was working yesterday morning and it doesn't work now but I'm convinced it's a library problem.
Team 2538
Plaid Pillagers
Morris, Minnesota
Rookie Year 2008
Unread 19-02-2010, 18:44
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
try rebuilding (right click project>Rebuild) It often solves some of our problems
Watchdog.Kill();
Unread 19-02-2010, 22:52
I've tried that already.
The situation has gotten worse, the Drivers Station LCD now also puts the robot in the same situation... help!
Team 2538
Plaid Pillagers
Morris, Minnesota
Rookie Year 2008
Unread 20-02-2010, 00:08
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
I tried to add the minimum camera code to the simple template to get camera to the dashboard. It builds, but when i download it it doesn't run because a symbol is missing: AxisCamera::GetInstance();
My includes are
#include "WPILib.h"
#include "Vision/AxisCamera.h"
#include "Vision/HSLImage.h"
My code calls:
HSLImage image;
camera.GetImage(&image);
Are those right?
You you have to call GetImage to get it to display on the dashboard?
Has anybody had any luck with the updated wplib?
Brian
Brian K
Team 1225 Robotics Mentor
AxisCamera2010.h not found d4mation C/C++ 2 13-02-2010 14:05
Vision Assistant Sykan NI LabVIEW 1 17-01-2009 16:43
Vision Illuminators Qbranch Programming 3 10-01-2008 03:20
n.e.r.d. vision feedback MattK General Forum 15 05-07-2006 20:11
n.e.r.d. Vision Episode 3! MattK General Forum 15 05-07-2006 13:06
