Go to Post Steampunk goggles are perfectly legal as forehead protectors. - Nuttyman54 [more]
Unread 18-02-2010, 13:24
urkelman91 urkelman91 is offline
FRC #3268
urkelman91 is an unknown quantity at this point
Thermoplastic Question
Is it legal?
Unread 18-02-2010, 13:26
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Thermoplastic Question
It probably depends what exactly you're talking about. If it is a part from the KoP that was made from thermoplastic, then it's probably legal. If it's a part your team made, and it meets all the requirements about what materials you can use (cost, COTS, etc) then it is probably legal.
If you want more specific information, please let us know what the part is, etc.
Unread 18-02-2010, 13:27
foote stepped in
AKA: E. Foote
FRC #0868
maybe.
Ask a more specific question, get a more specific answer.
Welcome to CD!
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 18-02-2010, 13:52
3286's Avatar
3286 3286 is offline
AKA: mike s
FRC #3286 (the Rock-It surgeons)
3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of
As I understand it, Plexiglass is not legal, Lexan is. Both are thermoplastics, but plexi has a greater tendancy to shatter or spliner, lexan is much more pliable. We just made some parts this morning to help keep errant soccerballs out of our robot with Lexan.
Mike
Unread 18-02-2010, 13:55
EricH EricH is online now
Mike, please re-read the allowed materials sections of the Manual. Plexiglass (or acrylic) is legal just the same as Lexan (polycarbonate). It's just a little bit more finicky about how you need to treat it if you don't like it breaking
As long as the thermoplastic is under the cost restrictions and weight restrictions, nothing says that you can't use it.
FRC #3268
To be specific, is thermoplastic legal for fitting components that are typically incompatible? For instance, fitting together a gear to a threaded bolt, each with differing diameters?
Edit: Punctuation
Unread 18-02-2010, 13:59
Edit: Punctuation
Is it legal? Yes. (Or rather, I don't remember any rule saying that you can't use it that way.)
Is it the best way to do it? That depends. If you have a machine shop, I'd see about making a coupler out of something like aluminum or a rather solid plastic.
FRC #3268
Thank you Eric.
Question Spiders Pneumatics 4 12-02-2008 19:00
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
A question double_check Rules/Strategy 12 08-10-2005 15:08
Serious thermoplastic problems!!! bigqueue Control System 10 28-02-2004 14:18
Question Jgreenwd1 General Forum 1 04-10-2001 15:19
