Go to Post Focus on solving the problem, not on being deliberately creative. If you effectively solve the problem, creativity is naturally leveraged as part of finding a great solution. - Jim Zondag [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 18-02-2010, 14:24
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
Re: CAN and Java
Right after I posted the above, I checked FirstForge, and low and behold, there was new CANJaguar code posted just this morning. Looks like Joe has been busy while we were pondering this issue, and discovered the same thing that you did. He has added a Speed Control example and modified the CANJaguar code to handle the proper settings.
Can't wait to try it out this afternoon!
Thanks Joe!
Can I use slot 6 for digital module in JAVA? mark.amber Programming 3 13-02-2010 10:56
Where can I find camera tracking code for Java? nikRbokRz Java 4 20-01-2010 23:35
You can explain how robotics can help with ocean discovery and sustainability. ebarker General Forum 0 30-09-2009 19:01
**FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION*** Pjohn1959 Programming 37 31-08-2009 15:55
Eclipse Plugin, Linux, and a Java Loader shtylman Programming 5 17-01-2008 14:44
