Re: no camera image in the dashboard
Axis Media Control is not used with the Dashboard display.
This new account, is it on the Classmate or another PC? If it's on the Classmate then you should run the Driver Station there as well, just to keep things together. If you're running the Dashboard on a separate PC, then the Driver Station needs to specify the IP address of that other machine (on the Setup tab). Have you installed all the latest Updates released this past Friday? |
| How to get the camera to show images on the dashboard? | whcirobotics | NI LabVIEW | 38 | 20-02-2010 11:55 |
| Lost the camera part of the dashboard... | 1168Programmer | FRC Control System | 5 | 15-02-2010 10:30 |
| Displaying Camera Image in C# Dashboard | PranavSathy | C/C++ | 12 | 08-02-2010 17:06 |
| Reinstall of dashboard doesn't fix camera image streaming | ellisk | Programming | 2 | 20-01-2010 08:04 |
| Can we use the camera image on Dashboard this year? | Jon236 | Programming | 1 | 11-01-2010 12:52 |
