Go to Post Now, most of the replies are very tactful when they are questioning a teams' design... but some are simply stupid. Keep your heads. - Andy Baker [more]
Unread 18-02-2010, 15:54
GunfighterJ's Avatar
GunfighterJ GunfighterJ is offline
AKA: Joseph
FRC #2450 (RaiderBots)
GunfighterJ is an unknown quantity at this point
Question Classmate connection possiblilty
I know that you can connect the classmate to the wireless router
(WRT610N) which in turn connects to the gaming adapter (WGA600N) on the robot. But is there anyway to bypass the WRT610N and connect the classmate directly to the WGA600N?
There are 10 types of people in this world. Those that understand binary, and those that don't.
Unread 18-02-2010, 16:51
Racer26 Racer26 is offline
Re: Classmate connection possiblilty
You mean like an Ad-hoc Wifi network between classmate and the bridge onboard the robot? Its plausible, though I'm not sure it would work as expected.
Why do you want to leave the router out of the equation?
Unread 18-02-2010, 16:52
No, not even with an Ad-hoc network, because the Classmate does not use N-wireless. It uses b/g.
At home ONLY, you can just supplant your gaming adaptor with the router on the robot. Not legal for competition though.
Unread 18-02-2010, 17:01
AKA: Joseph
Ok thank you. But I hav4e another issue, we needed to reconfigure the wireless bridge. But now we can;t connect to it, we configured it's ip to 10.24.50.1 like it;s supposed to be, but somehow the static ip was changed to DHCP and now we can;t connect to it. Any help would be neccessary.
Unread 18-02-2010, 17:13
Which device is set to use DHCP- the Classmate or the Gaming Adaptor?
If it's the Gaming Adaptor you can find it's current IP in the router DHCP table. Just browse to the router and look for it in the Wireless tabs.
Worse comes to worse, you always have the option of resetting the gaming adaptor to factory defaults (red recessed button on the back).
Unread 18-02-2010, 21:34
The bridge also doesn't support ad-hoc networks.
Unread 18-02-2010, 21:52
AKA: Joseph
We got the router working again. Just had to reset to factory defaults.
Restore Classmate mcbean Control System 7 04-11-2010 23:47
Classmate troubles jaster67 Control System 4 26-01-2010 20:38
classmate configration yara92 Technical Discussion 10 25-01-2010 13:58
Classmate PC lon.bushweiler Control System 8 22-01-2010 14:46
Classmate MachineSMMC NI LabVIEW 10 15-01-2010 13:47
