Go to Post Gotta love the blurred robots :cool: - Steven Donow [more]
Unread 18-02-2010, 16:31
Racer26 Racer26 is offline
Re: Compressor won't start
The compressor WILL NOT RUN without the pressure switch connected, this is because the switch is a normally closed contact, that goes open when its reached pressure.
The code you showed shows Digital In 4 as where its expecting the switch, and Relay 2 as where its outputting the signals. The LEDs on the sidecar near the relay ports will switch when its working.
Also, I highly recommend using pointers instead of directly instantiating your objects:
class myRobot : public SimpleRobot
RobotDrive* driveBase;
Jaguar* someMotor;
Solenoid* someSolenoid;
Compressor* theCompressor;
myRobot(){
driveBase = new RobotDrive(1,2,3,4);
someMotor = new Jaguar(5);
someSolenoid = new Solenoid(1);
theCompressor = new Compressor(1,1);
theCompressor->Start();
void Teleop(){
someMotor->Set(1);
This way, you can pass them by reference, instead of by value, which breaks things. Its good practice.
Compressor won't start Alex_2487 C/C++ 6 12-02-2009 16:41
Wind River won't start radau C/C++ 6 19-01-2009 23:09
Won't Download! diaperrash89 Programming 4 25-10-2007 23:02
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Help! My 2003 Bot compressor won't shut off Jack21 Control System 10 11-02-2004 12:24
