Go to Post Mentors can either hide the experience of failure or support the right of a student in gaining that experience. - dcbrown [more]
Unread 15-02-2010, 13:37
tariqzahroof tariqzahroof is offline
FRC #3335
tariqzahroof is an unknown quantity at this point
OTA Server Error
We have used a simple program which just utilizes 2 joysticks to move tank-style. When try to 'Run Main Project' to send the program to the robot, we get:
Connecting to FTP @10.33.35.2
upgrade:
Sending local file image.suite
flashapp:
deploy:
init:
Waiting to connect to OTA command server of 10.33.35.2:0001 for past x seconds
We waited about 2 minutes, and after assuming that nothing was occuring, other than the seconds increasing, we stopped the program. We have updated the cRIO image to version 19, and we have fully updated NetBeans.
Can someone help?
Unread 16-02-2010, 14:15
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Re: OTA Server Error
1713 has the same issue, only after we upgraded to v20. Any help would be greatly appreciated.
Although it seems the code stays on the robot if it's rebooted. Not sure why, but it runs.
EDIT: It seems a reboot of the cRIO fixed it.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 16-02-2010, 15:43
imcmahon01 imcmahon01 is offline
FRC #1143
imcmahon01 has a spectacular aura aboutimcmahon01 has a spectacular aura aboutimcmahon01 has a spectacular aura about
Thanks Ethan! It does seem a reboot of the robot after the v20 imaging solves the OTA Server Error
Unread 16-02-2010, 17:53
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
I just saw this myself. To be specific, you need to reboot the cRIO manually after running Netbeans the first time after updating for v20.
Unread 16-02-2010, 20:52
1168Programmer 1168Programmer is offline
Head Programmer/CEO
FRC #1168
Team Role: Student
1168Programmer is an unknown quantity at this point
We are having the same problem after updating to v20. I have tried power cycling the cRIO and pressing the reset button. Neither of those actions corrected the problem.
Do you have any other suggestions that we could try?
Thanks in advance.
Unread 18-02-2010, 16:20
Drucifur Drucifur is offline
FRC #0614
Drucifur is an unknown quantity at this point
We need help, too...
Unread 18-02-2010, 16:35
derekwhite's Avatar
Drucifur,
In another post, 1168Programmer seems to have gotten past this issue (http://www.chiefdelphi.com/forums/sh...2&postcount=20)
If that post doesn't seem to help you, could you post your output? It could be a different problem...
Unread 20-02-2010, 23:09
Head Programmer/CEO
FRC #1168
Team Role: Student
Originally Posted by derekwhite View Post
Drucifur,
Yes we were able to get our cRIO back into a state where we can download and run our code. However, late last night we discovered that we are only able to do so when the cRIO is not in safe mode. (We had forgotten to switch it back to safe mode after reimaging.) When I put it back into safe mode, we started getting the OTA server error again. Rebooting did not help.
Turning safe mode off allowed us to download and run code normally again. Has anyone encountered this before? I would like to be able to keep the cRIO in safe mode, but I suppose that is not completely neccessary...
Unread 21-02-2010, 08:54
The safe mode toggle is not like safety goggles for the cRIO. It means that the cRIO will only load a small number of drivers. You do not want to have the safe mode dip on unless you are having problems with a corrupted image and want to flash or debug it.
Read the cRIO documentation if you want a more complete explanation of what the dips do.
Greg McKaskle
Unread 21-02-2010, 10:43
Head Programmer/CEO
FRC #1168
Team Role: Student
Greg McKaskle
Ah, thanks. I did not realize that.
MPLAB error: Error [1027] unable to locate 'serial_ports.h' rokenboker Programming 10 03-09-2009 16:29
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
