Go to Post They showed me a new item and said "we don't know how to list this on the inventory." I took one look, started laughing and said "In my world that is called a game piece, aka, a tote." - RoboMom [more]
Unread 18-02-2010, 10:29
Re: No Robot Code
What messages or response do you get when you push the "Run" button on Robot Main.vi?
Originally Posted by SchrödingersCat View Post
Our team is having the same problem. We installed LabVIEW update 2.1 and Driver-station update 1.1 on the Classmate, updated the cRIO image to v20. We can only connect with the driver station while LabVIEW is not loaded (we cannot run the code in a real time connection). It still displays "No Robot Code".
Any ideas would be lovely.
Unread 18-02-2010, 10:47
SchrödingersCat SchrödingersCat is offline
FRC #0931
SchrödingersCat is an unknown quantity at this point
Re: No Robot Code
It seems to deploy correctly. I have a indicator on the Iteration Count within the while loop in Robot Main.vi, and it increments about once per second (as the driver station is not connected).
When I attempt to start the Driver Station, the connection between the cRIO and LabVIEW times out and stops entirely. Then the Driver Station connects, and still says, "No Robot Code".
Unread 18-02-2010, 10:56
Re: No Robot Code
Have the Driver Station application running before you try to run the robot code.
Unread 18-02-2010, 10:58
FRC #0931
Re: No Robot Code
I can try this, but I believe LabVIEW wouldn't connect at all with the Driver Station already running (and connected).
Unread 18-02-2010, 11:11
Re: No Robot Code
You have Exited the Driver Station in the Driver users account and are running it only in the Developer account aren't you?
Not switching back to the Driver account to run the Driver Station.
Unread 18-02-2010, 11:31
FRC #0931
Re: No Robot Code
Yes, I hold SHIFT while windows comes up so I login only the Developer account, and run the Driver Station while in Developer.
Unread 18-02-2010, 12:43
Re: No Robot Code
Sounds weirdly like only one app can use the network connection at a time.
You can also try turning off the Classmate wireless while you are trying this, so we know it isn't port confusion.
Have you changed the Classmate much, if at all, from it's original condition by installing third-party software?
Unread 18-02-2010, 14:22
FRC #0931
Re: No Robot Code
No, in fact, I just used the Restoration Key and installed all the updates.
Unread 18-02-2010, 17:04
FRC #0931
Lightbulb Re: No Robot Code
Got it working. I created a new blank cRIO FRC Project with all the updates installed, and magically everything works.
Unread 18-02-2010, 17:06
Re: No Robot Code
Might have been a mix of old version code then.
Good news.
Unread 18-02-2010, 17:09
FRC #0931
Re: No Robot Code
Good news.
Actually, the old code from before I re-imaged the Classmate worked perfectly now that everything was properly installed.
No Robot Code After downloading Code tutkows1 FRC Control System 2 08-02-2010 00:51
No Robot Code eaglesfan10 C/C++ 6 03-02-2010 22:34
Compressor Code causes No Robot Code Error sircedric4 C/C++ 25 03-02-2010 10:13
No Robot Code mlim NI LabVIEW 10 21-01-2010 17:33
Robot Code? leftylink Programming 0 18-02-2008 14:34
