Go to Post If there is anything I have learned from ChiefDelphi, it's to never underestimate the coding genius that is Brandon Martus. - Amanda Morrison [more]
Unread 18-02-2010, 17:15
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Using swing for Dashboard
We've done most of our programming in Java and we want a custom interface for our robot. So, we've decided to use Swing to do this. How could we get the robot to send info to the Dashboard? Is there some documentation we can read up on the protocol through which the robot communicates? Thanks in advance.
Unread 18-02-2010, 21:29
Lord_Jeremy's Avatar
Lord_Jeremy Lord_Jeremy is offline
Lord_Jeremy the Procrastinator
AKA: Jeremy Agostino
FRC #1546 (Chaos Inc.)
Team Role: Electrical
Lord_Jeremy is an unknown quantity at this point
Send a message via ICQ to Lord_Jeremy Send a message via AIM to Lord_Jeremy Send a message via MSN to Lord_Jeremy Send a message via Yahoo to Lord_Jeremy
Re: Using swing for Dashboard
Check out the sunspotfrcsdk javadoc. Specifically, look up the DriverStation class. It has a nice, easy way to output to and control the elements of the DriverStation dashboard.
Compiling...
Compiling...
Unread 19-02-2010, 16:10
spartango spartango is offline
FRC #0192 (GRT)
spartango is an unknown quantity at this point
its currently a work in progress.
https://squawk-frc.dev.java.net/sour...hostdashboard/
Unread 02-03-2010, 11:00
FRC #0192 (GRT)
I've released my test swing dashboard:
svn checkout http://grtframework.googlecode.com/svn/trunk/ grtframework-read-only
its under FRCDashboard.
Unread 02-03-2010, 19:20
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
it says i cant compile it, can you post a jar of it?
Unread 02-03-2010, 22:37
FRC #0192 (GRT)
Fixed that issue and posted a binary.
Check out
http://code.google.com/p/grtframewor...CDashboard.jar
Unread 03-03-2010, 17:47
1 * 4 != 14
ok, thanks.
How would I get information like the current victor speed to be displayed in a text box?
Unread 09-03-2010, 22:06
FRC #0192 (GRT)
This dashboard was meant as a proof-of-concept...that swing dashboards could be used without too much pain. I'd really like to write a more flexible one, but havent had the time.
If you would like to modify the dashboard, look at the source. The UI is pretty much entirely generated with the Netbeans UI builder(Eclipse's VEP didnt work on my Java EE build ) so i suggest that you open the project in netbeans and edit the Dashboard JPanel.
Unread 02-04-2010, 02:03
Programming
Thanks for your code! We ended up using LabVIEW to program our interface because there were parts of the code I couldn't understand.
Would it be possible to simplify this to only a single class which gets packets from the robot, and then reassemble them back into the clusters which they were originally from? We might be using something similar to this next year
Thanks in advance!
Unread 03-04-2010, 19:36
FRC #0192 (GRT)
I have been working with ericarseneau(from Sun, Project Squawk) on this one, and expect that there will be an easy to use Swing system for building java dashboards by next season. While I wont be around to see it finished, GRT (192, Palo Alto CA) will do its best to pursue it and let it be used by all teams...
Selecting autonomous modes using FRC PC Dashboard ellisk C/C++ 5 07-02-2010 10:31
Is anyone using the Labview Dashboard during competition? programmr General Forum 11 05-02-2009 17:06
Using FRC dashboard w/ camera during competition? asianfez123 FRC Control System 2 05-02-2009 15:56
Using FRC dashboard w/ camera during competition? asianfez123 Rules/Strategy 7 24-01-2009 22:07
Swing Dancing Pamela Chit-Chat 7 29-06-2002 14:14
