Go to Post Multitasking is a myth. - DonRotolo [more]
Unread 18-02-2010, 17:38
JP Carlin's Avatar
JP Carlin JP Carlin is offline
FRC #2487 (Mechanical Animals)
JP Carlin is on a distinguished road
Question problem with logitech attack 3 controller
after trying to work out some bugs in our tele-op program something went wrong with our joystick. i am not sure if this was a mistake made while i was programming but the joystick will move the motor it is controlling forward when it is in a neutral position. it is only when the controller is moved back slightly will it recognize that it is in neutral. is there anyway to fix this in the program or is it something wrong with the joystick? if anyone could help me reset the dead band of the controller or extend it to include where it normally should be it would be greatly appreciated.
Unread 18-02-2010, 17:42
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: problem with logitech attack 3 controller
The best solution is to power the driverstation down, and when you power back up, don't touch the joystick until everything is back up and running.
Sometimes, if somebody is moving the joystick when the DS is coming up, the software can "latch" the current position of the joystick and offset the 0,0 point.
I suppose that unplugging and re-plugging it in might also fix it, but I'm just guessing here.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 18-02-2010, 18:41
JP Carlin's Avatar
thank you for the advice i just have to wait for robotics to start tomorrow morning so that i can test it. i thought a very similar thing but everyone claims they didn't do it. thank you for the help.
Unread 19-02-2010, 07:54
Unplugging and plugging should work just fine. This seems to happen more often with gamepads. It is easier for something to be sitting on top of them or for them to be upside down or have a cable running across the controls.
Greg McKaskle
Unread 19-02-2010, 09:59
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
this is same exact thing that happened to me. I unplugged and replugged it a few times, until the values were correct, button inverted. That is as good as I got. If you get past that, please let me know
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 19-02-2010, 20:25
JP Carlin's Avatar
turns out that there never really was a problem with the actual controller but i made an error in the program. after plugging the controller into the joystick input example i found that the controller was working correctly and was able to fix the problem in the program.
Logitech attack 3 joystick problem JP Carlin Programming 1 18-02-2010 21:50
controller sensitivity for logitech gamepad Hustler NI LabVIEW 2 02-02-2010 00:15
Problem with Controller rzienta FRC Control System 1 22-01-2009 12:05
problem with speed controller gaby1367 Electrical 11 14-05-2007 22:16
Problem with the 2005 controller Guy_E Programming 10 18-12-2006 01:38
