Go to Post I am specifically looking for Rhode Island, Hawaii, New Hampshire, Nevada, California, Florida, ... oh heck, all of the rest. - Rosiebotboss [more]
Unread 18-02-2010, 18:18
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
LED Set method
Ok, so our team wants to have certain LEDs light up when tasks are being performed. I have gotten the DriverStation enhanced IO LED.get method, but i can't figure out how to set the lights to go on or off. The set method requires a 1D array as input, but i only want certain lights to go on and off. Do i just change the boolean value in the array, or is there more than meets the eye. Pre-thanks in advance.
Team 810's only vet programmer.
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
Unread 19-02-2010, 07:51
Re: LED Set method
You figured it out. Each write affect all of the LEDs. So you can use Boolean logic on the array, or array operations to Replace the ones in the array. You can also Build the array from what you want to set/clear.
Greg McKaskle
Java VisonChaser method Robototes2412 Java 0 15-02-2010 15:19
Pneumatics release method camper365 Pneumatics 5 12-01-2010 18:29
New compression method Aalfabob Programming 99 03-10-2004 16:21
Autonomous Method Astronouth7303 Programming 3 25-02-2004 17:14
Scouting method suggestiongs punarhero Scouting 0 26-01-2003 04:27
