Go to Post To help keep the kids on top of their game, I remind them that the school board considers a grade of 97 an A , so we can lose 3% of the kids and still be considered excellent. - DonRotolo [more]
Unread 18-02-2010, 20:27
Re: Status driver station issue
If you are feeding the watchdog, but not feeding as often as you said you would, you'll get this behavior. I'd inspect the code to see how often and for how long your yields are delaying the code. Certain routines such as Teleop need to return quickly or they will cause you to miss joystick packets. If these are OK, look to either feed more often or adjust the period so that it doesn't expect to be fed any more often.
Remember. The user watchdog helps you know when your code isn't running as often as you thought it would, and gives it a way to fail safely when certain mistakes are made such as crashing or infinite loops.
Greg McKaskle
A Captian and Driver Issue R.C. General Forum 26 27-10-2010 00:41
Driver Station Missing 'nicyapi.dll' Issue. Twisted eric Programming 4 14-02-2010 21:14
2009 Driver Station Issue EricWilliams Control System 5 22-01-2010 14:59
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver Station Watch Dog / Motor Won't Spin Issue RMiller FRC Control System 5 20-01-2009 09:58
