Go to Post Practice field Practice bot Iteration = awesome sauce - Akash Rastogi [more]
Unread 18-02-2010, 21:03
Re: A question about the robot's light
Originally Posted by J_Beth View Post
We took a PWM and cut off the side with the male connector, and striped those ends and wired like the diagram showed us.
The RSL connector on the Digital Sidecar has only two pins. A PWM connector has three. You should have received a handful of two-wire cables with exactly the connector needed in the Kit of Parts. See the top of page 12 in the Kit of Parts Checklist.
question about the trailer haxor5354 Technical Discussion 1 09-02-2009 21:16
Question about the signal light Carmelulu` General Forum 2 05-02-2009 23:08
[OCCRA]: Question about a light MatthewArthur OCCRA Q&A 1 26-10-2005 22:21
turn on the light - question powercat Programming 12 22-02-2003 17:33
About the light that need to be seen from four side archiver 2000 3 23-06-2002 23:01
