Go to Post Thanks, that clears things up a lot, and should probably have been obvious. - Branden Ghena [more]
Unread 18-02-2010, 20:54
dooglius dooglius is offline
FRC #3173
dooglius is an unknown quantity at this point
Problems with new updates (I think)
We installed the new software updates (Labview and Driver Station), but now our code does not work.
We can no longer access the Can Jaguars (and we made sure to re-add the driver file after updating to cRIO v20), and when getting voltage, we get the error on the attached screenshot. We did not have this problem until we installed the new software.
Unread 18-02-2010, 22:11
misko misko is offline
FRC #0852
misko is an unknown quantity at this point
Re: Problems with new updates (I think)
There was a new update for WPILib posted last night. It was intended to fix a problem with the axis camera, but have you tried it just in case?
Unread 19-02-2010, 05:42
FRC #3173
Yes, we installed the workbench update 4.3 along with the Labview, Driver Station, and cRIO updates
Unread 19-02-2010, 14:44
FRC #3173
We fixed the exception (DriverStation *ds was not being passed properly; was null), but the jaguar /gyro problems are still present.
Unread 19-02-2010, 15:19
FRC #3173
Never mind, problem has been solved.
Problems with the watchdog (I think) Thxe C/C++ 9 08-02-2010 15:41
Problems with the newest updates... koo_04 Programming 4 16-02-2009 01:09
Israel Regional thread with updates Greg Needel Regional Competitions 10 29-03-2006 15:12
Array problems( i think....) Andrew Blair Programming 10 22-09-2005 19:57
ADC problems with C library and new code Larry Barello Programming 1 09-01-2004 22:31
