Go to Post The only thing that would finish this perfect day is a game hint... - [more]
Unread 17-02-2010, 17:22
Dakota Dakota is offline
FRC #2805
Dakota is an unknown quantity at this point
How do i program compressor
I give up trying to program the thing. I have the pressure switch hooked up to DIO channel 1, and the relay to relay channel 1. Both are on slot 4. How do I program the compressor?
Unread 17-02-2010, 17:39
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: How do i program compressor
What happens when you place the "Compressor Open" and "Compressor Start" in the Begin.vi with the correct DIO's and channels selected for the switch and relay?
Additionally, when you probe the signals, what does it show for the switch input and the direction command to the relay?
Unread 17-02-2010, 18:18
FRC #2805
How do I set that up? I tried the following with no luck.
In Begin:
Compressor open--->Compressor Start--->Compressor Refnum set
In Finish:
Compressor Refnum Get--->Compressor Stop--->Compressor Close
Is that right? How do I do it?
Unread 17-02-2010, 18:32
billbo911's Avatar
In Begin:
In Finish:
That sounds correct. My understanding is that is all it would take to make it work, that is, if you made sure to have the DIO's and channels correct, which it sounds like you did.
Also, make sure your DSC has power and the there is a circuit breaker feeding the relay and you have replaced the fuse in the spike with a 20amp circuit breaker.
If this doesn't work, which it never did for us, reply back and I'll post what we did to get it to work. BTW, search for issues with compressors. There are several threads about it and some also have solutions.
Unread 17-02-2010, 19:01
vidhur vidhur is offline
FRC #2582
vidhur is an unknown quantity at this point
We also had many difficulties running the compressor example codes and our code. What worked for us in the code was to incorporate a teleop vi also.
In Begin:
In Teleop:
Compressor Refnum Get---> Compressor Enabled
In Finish:
From my understanding you need to have the compressor enabled vi in order to run the compressor. Some teams open it in the begin vi before the Refnum set, but mine works fine in the teleop
If it still doesnt work, I have some tests to help you pinpoint the problem.
Unread 18-02-2010, 22:29
FRC #2805
Ok I got it. I thought that digital inputs were pulled down, turns out they are pulled up. |P
I touched the ground wire to the wire hooked up to "A" on DIO 1, and the compressor turned on. *smacks self on forehead*
Unread 18-02-2010, 23:07
billbo911's Avatar
Don't feel bad my friend. I'm a EE and I still need to remind myself each year whether the system looks for an open or closed contact to be considered active. Pulled up sometimes, pulled down others. Testing the result is the only sure way I know.
How do you code the compressor? Jessi-Team 2156 Technical Discussion 13 11-02-2010 15:14
How to program solenoid and compressor? Jason F Java 8 08-02-2010 15:15
How to conect solenoids to the circuit board. and how to program it...??? arpitshah Pneumatics 6 13-01-2008 15:06
pic: How we cool our compressor eshteyn Extra Discussion 19 28-07-2007 22:39
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
