Go to Post I can still remember how weird it was to look on the other side of our booth and see a kid in a suit tossing purple balls... - OneAngryDaisy [more]
Unread 12-02-2010, 20:42
Free Willy's Avatar
Free Willy Free Willy is offline
Free Willy is an unknown quantity at this point
Vibration Isolation Mounts
In the pneumatics manual it says to use vibration isolation mounts for the air compressor. Where can we find some that are compatible with the KOP air compressor?
Unread 12-02-2010, 21:08
TestEngr571 TestEngr571 is offline
AKA: Dana Susca
FRC #0571 (Team Paragon #571)
Team Role: Electrical
TestEngr571 will become famous soon enough
Re: Vibration Isolation Mounts
McMaster-Carr has them!
Unread 12-02-2010, 21:17
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
http://www.mcmaster.com/#9376K17
Unread 12-02-2010, 22:28
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
My team mounted it on top of some of the IFI wheel tire tread. That (and Loctite, gosh darn the stuff) made it work.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 12-02-2010, 22:33
The isolation mounts are provided to cut down on noise, they do not effect the operation of the compressor.
Unread 18-02-2010, 18:54
superdb superdb is offline
FRC #2369
superdb is an unknown quantity at this point
Does anyone know if there is an issue with performance or legality of mounting the compressor upside down?
Unread 18-02-2010, 22:40
Super,
The only issue would be heat. As the compressor does it's thing, the head gets hot. Upside down the heat from the head would rise into the body of the compressor. A fan might help. Do not use the vibration isolators that came with the pump though. They are designed for compression and I have seen them fail when used in other orientations. You can purchase other types as linked above or you can hard mount the pump. it will still vibrate and will make more noise as the vibration is transferred into the robot frame. You could also hard mount it on a small plate and then isolate the plate from the frame of the robot to quench vibration noise.
Unread 18-02-2010, 23:16
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Upside-down? I don't know the meaning of that word/phrase!
(I Don't know of any reason why it should or would affect the performance. To the best of my knowledge there is no rule regarding orientation; but I don't know for sure because I can't find that rule.)
Unread 19-02-2010, 00:08
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
The KOP compressors have been proven to work just fine in Australia. So I don't think there will be a problem.
-dave
Unread 19-02-2010, 07:17
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
-dave
We do have an old one that works a bit funny, though...
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 19-02-2010, 07:40
Dave,
Add Chile and Brazil to that list. Of course the air in the tubing spins counter clockwise.
Correlation, Causation, and the Isolation of variables in FiM District Structure Lil' Lavery General Forum 13 30-04-2009 20:09
chassis isolation, contrary to UL1740? grambo Electrical 10 18-10-2008 20:18
Bumper Mounts Sam N. Technical Discussion 18 17-02-2008 20:19
Filtering out Vibration while using a KOP Accelerometer joshyboy9987 Electrical 31 22-01-2008 08:20
Motor Mounts archiver 2001 3 23-06-2002 23:29
