Go to Post Sooo....in the famous words of Douglas Adams, Don't Panic. - Conor Ryan [more]
Unread 18-02-2010, 16:42
chanchan1193 chanchan1193 is offline
FRC #3215
chanchan1193 is an unknown quantity at this point
16bit controllers
We are attempting to use a 16bit Xbox 360 Controller to drive the robot with arcade drive. We have changed all of the values from 8 bit to 16 bit but the program and dashboard don't output the joystick values in 16bit. Is there anyway to edit the dashboard to allow us to use 16 bit?
Unread 18-02-2010, 17:51
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: 16bit controllers
If you are trying to get increased resolution from a Joystick axis, that is not possible. The data sturcture used between the DS and robot is fixed at 8 bits per axis.
Why do you believe you need the higher resolution?
Eric Haskins KC9JVH
Unread 18-02-2010, 19:19
FRC #3215
Could you point out exactly where in the DS it states that it is in 8 bit. If we have access to this, we could change the data type like we did in the robot main portions of the code. Is it in the compiled, system portions?
Unread 18-02-2010, 19:33
AKA: Eric Haskins
The DS code is not provided. Only the dashboard code is.
Making that change would require access to DS code and robot network communication code. Neither of these pieces are provided.
Even if you did, it still wouldn't be possible to make those changes and comply with the robot rules since the DS and robot communication library versions are specified by the rules, and verified by the FMS.
Eric Haskins KC9JVH
Unread 19-02-2010, 01:05
bobsaget2010 bobsaget2010 is offline
bobsaget2010 is an unknown quantity at this point
16 bit WORKS!!!!!!!!!! the joysticks you have now are 16 bit!!!!
IT IS MADE FOR 16 BIT!!! WOOOHOOOO!!! GO CRAZY AND USE XBOX 360 CONTROLLERS!!!
Unread 19-02-2010, 07:12
FRC #3215
woot
IR controllers Bsteckler General Forum 1 23-02-2008 11:07
Controllers? joshR515 Control System 1 21-02-2006 16:06
PS2 Controllers RoboMadi Programming 3 04-11-2005 16:52
pic: Controllers Alexander McGee Extra Discussion 11 22-12-2004 08:09
Speed controllers.... Denman Technical Discussion 14 07-10-2004 15:19
