Go to Post In any case, a drawing is important. You should never machine anything without having a drawing of some type to work from. - Big Ideas [more]
Unread 18-02-2010, 21:52
ZachR's Avatar
ZachR ZachR is offline
Programmer
FRC #3210 (Falcons)
ZachR is an unknown quantity at this point
Linear Based Encoder
We are *planning* on making a linear encoder for our kicker. Would there be anyway to mesure its resistance? And how would one go about wiring it up?
Unread 18-02-2010, 21:57
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Linear Based Encoder
Why would you need a linear encoder when you can have A. a potentiometer or B. a slide potentiometer?
If there is a joint you can measure with either, you could feed it +5 and GND and it would feed you volts.
Kettering Motorsports
Unread 18-02-2010, 23:25
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
I agree there are likely places you could mount a more typical encoder or pot. If you really get stuck, though, we used a string pot last year. Check them out at http://www.celesco.com/index.htm. The SP series is what we used. They are basically a multiturn pot inside a housing with a spring return and, of course, a string (steel cable). Quite slick, also fairly expensive ($150+) so exhaust other options first.
Unread 19-02-2010, 08:12
Zach,
I am guessing you are trying to measure kicker position before a kick to set the distance of the kick. Depending on your design a pot should give you the range sine you can't move the kicker anymore than 90 degrees or so. This application would tough on a pot unless it was isolated from vibration. You might use a series of light sensors though. Your accuracy doesn't have to get down to fractions of an inch so say five sensors tops. that would give you the ability to have five different kicker distances. Easy to program too. If you use some of the little interuptor sensors from Digikey, you can have a small plate with holes attached to your kicker. And then you just count the holes with a single sensor.
Screwing Encoder into Encoder Mount? Adrien Electrical 3 25-01-2009 18:14
Linear slides Andrew Schuetze Kit & Additional Hardware 10 18-01-2008 23:37
Linear Control 987HighRoller Control System 1 31-01-2007 02:43
Linear Actuator NoRemorse General Forum 4 17-01-2004 21:02
Linear slides Gui Cavalcanti Technical Discussion 4 02-01-2004 15:59
