Go to Post a Victor is a Victor is a Victor. - Billfred [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 19-02-2010, 09:19
Racer26 Racer26 is offline
Re: 2010 Trenton New Jersey unbricking offer
1075 smoked a black jag, and then replaced it with a grey one... partway through the night the grey one just stopped working. The light doesnt come on at all, no smoke was released, and the fuse audibly arcs when being plugged into the PDB. Could this be that? Or do you think this Jag is somehow toasted?
Edit: it was brand new out of the box, wired correctly, and working a few minutes before it wasnt. the black jag's smoke release was user-induced. the grey one... we're stumped.
Unread 19-02-2010, 19:22
Jim Giacchi's Avatar
Jim Giacchi Jim Giacchi is offline
FRC #0041 (Robo-Warriors)
Jim Giacchi will become famous soon enoughJim Giacchi will become famous soon enough
Send a message via AIM to Jim Giacchi
Sure sounds like its a firmware issue. Same thing happened to us three times, Jaguar is fine one moment, next moment it just stops blinking with no explanation at all. We bought the JTAG programmer to fix it and we've recovered 3/3 Jaguars so far. Its certainly worth a shot. If you have someone good at soldering and you can put the header in it would make it easier for us, but if you can't we can do it for you and then try a reprogram it. No guarantees, but we will certainly try to fix it for you if you bring it.
Jim Giacchi
Team 41 - Head Coach
Unread 20-02-2010, 00:31
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
I would switch that breaker, it might be faulty if you hear it arcing inside. The jaguar could also be shorted internally, which is causing the breaker to over current, and thus trip. You might want to open the jaguar and check for metal shavings.
Here is what I would do if I were you. First isolate it so it is the only thing on the CAN bus. Do not forget your terminator. Now upload the firmware to any number, and hope it accepts it. If you are using the 2CAN and you get a timeout response,then it is truely bricked. If it is stuck in bootloader it would accept the upload. Power cycle to bring it back after.
If you use the black jaguar as your bridge, then I direct you here.
Don't worry, we are 5/5 (bricked/recovered) now after updating to 89.
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
2010 New Jersey Regional DonRotolo Regional Competitions 184 02-10-2010 12:03
[FF]: 2010 New Jersey League 1 Koko Ed Fantasy FIRST 43 26-02-2010 18:52
[FF]: 2010 New Jersey League 2 Koko Ed Fantasy FIRST 32 26-02-2010 18:44
New Jersey Videos Sean Marks Regional Competitions 6 27-03-2007 08:48
[FF]: New Jersey 2007 Sgraff_SRHS06 Fantasy FIRST 174 04-03-2007 05:57
