Go to Post The championship could be in a swamp infested with flying insects, and it would still rock the world :D - kristen [more]
Unread 12-02-2010, 23:01
firebat2222 firebat2222 is offline
FRC #2272
firebat2222 is an unknown quantity at this point
Using WPIlib with Acroname R117 Compass?
Hi,
I don't think we received a gyro with our FRC 2010 kit, but we did receive an Acroname R117 compass. Unfortunately, there is no method in the WPIlib to access the R117 compass. We're trying to get the Hitech Compass class to read the R117 compass, but it's not working.
The first problem was that the Hitech Compass routine has a verify manufacturer routine. Then we tried hacking out the verify manufacturer routine, but still we couldn't get data from the R117.
Finally, we found an NXT Hitech compass from our FTC kit and he we hooked that up. Still, the HitechCompass class gave us a invalid manufacturer.
Anybody have any idea how we could rectify the situation?
Unread 13-02-2010, 02:39
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Using WPIlib with Acroname R117 Compass?
The first thing I suggest is that you review the Sensor Manual.
http://usfirst.org/uploadedFiles/Com...ual%20RevA.doc
How did you determine you received an R117 in the KOP?
The HiTechnic compass should work out of the box. If it isn't working please post details of how you connected and programed the compass.
If you still have questions, please post again.
Eric Haskins KC9JVH
Unread 19-02-2010, 11:19
spartango spartango is offline
FRC #0192 (GRT)
spartango is an unknown quantity at this point
Keep in mind that the gyro is attached to the same (large-ish, blue) circuit board as the accelerometer this year. It can be snapped off however.
Unread 21-02-2010, 21:31
michael714's Avatar
michael714 michael714 is offline
FRC #3863 (Pantherbotics)
michael714 is on a distinguished road
You were right. We did not receive the Acroname with the kit. One of our mentors threw it in our parts box. Also, we did find the kit gyro and accelerometer. Thanks!
Get Motor Values with WPILib? Adrien Programming 2 03-02-2008 12:12
Using WPILib RyanW Programming 1 19-01-2008 17:15
Interfacing a digital compass with the RC Kelly Electrical 14 27-09-2007 19:01
Code Won't Compile in MPLab with WPILib Inverted Programming 1 20-02-2007 22:12
Using WPILib on a Vex robot koenig3456 Programming 2 02-05-2006 14:56
