Go to Post So.... football pizza water game with minibots and megabots? - euhlmann [more]
Unread 19-02-2010, 11:31
batmankiller batmankiller is offline
None #2601
batmankiller is an unknown quantity at this point
Re: Status driver station issue
Originally Posted by Greg McKaskle View Post
If you are feeding the watchdog, but not feeding as often as you said you would, you'll get this behavior. I'd inspect the code to see how often and for how long your yields are delaying the code. Certain routines such as Teleop need to return quickly or they will cause you to miss joystick packets. If these are OK, look to either feed more often or adjust the period so that it doesn't expect to be fed any more often.
Remember. The user watchdog helps you know when your code isn't running as often as you thought it would, and gives it a way to fail safely when certain mistakes are made such as crashing or infinite loops.
Greg McKaskle
We're using iterative robot template.. so do we put it in teleop periodic?
Here's our code... if anyone's intersted
/* Copyright (c) FIRST 2008. All Rights Reserved.                             */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
//Sky Hawk
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.PIDController;
import edu.wpi.first.wpilibj.PIDOutput;
//import edu.wpi.first.wpilibj.Relay;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.camera.AxisCamera;
import edu.wpi.first.wpilibj.camera.AxisCameraException;
import edu.wpi.first.wpilibj.image.ColorImage;
import edu.wpi.first.wpilibj.image.NIVisionException;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class SkyHawkVersion3 extends IterativeRobot {
    double kScoreThreshold = .01;
    AxisCamera cam;
    private DigitalInput i1 = new DigitalInput(2);
    private DigitalInput i2 = new DigitalInput(3);
    private Solenoid s1, s2, s4, s3;
    private Compressor airCompressor;
    Gyro gyro = new Gyro(1);
    private Victor roller = new Victor(6);
    private Victor flyWheel = new Victor(5);
    private Victor release = new Victor(8);
    private Victor arm = new Victor(7);
    //private Relay spike1 = new Relay(1);//Relfay 1
    private Joystick stickRight = new Joystick(1);//USB 1
    private Joystick stickLeft = new Joystick(2);//USB 2
    private Jaguar rightBackJaguar = new Jaguar(1);//PWM 1
    private Jaguar rightFrontJaguar = new Jaguar(2);//PWM 2
    private Jaguar leftBackJaguar = new Jaguar(3);//PWM 3
    private Jaguar leftFrontJaguar = new Jaguar(4);//PWM 4
    private double sensitivity1;//Right Joystick Sensitivity
    private double sensitivity2;//Winder sensitivity
    private double y2;//Left Joystick Y-axis
    private double x2;//Left Joystick X-axis
    private double y1;//Right Joystick Y-axis
    private double x1;//Right Joystick X-axis
    private double rightBackSpeed;
    private double rightFrontSpeed;
    private double leftBackSpeed;
    private double leftFrontSpeed;
    TrackerDashboard trackerDashboard = new TrackerDashboard();
     PIDController turnController = new PIDController(.08, 0.0, 0.5, gyro, new PIDOutput() {
        public void pidWrite(double output) {
           // drive.arcadeDrive(0, output);
    }, .005);
    public void Airsystem() //turns on the enitre air system
          airCompressor = new Compressor(1,2);  //Digtial I/O,Relay
          airCompressor.start();               // Start the air compressor
          s1 = new Solenoid(1);               // Solenoid port
          s2 = new Solenoid(2);
          s3 = new Solenoid(3);
          s4 = new Solenoid(4);
          s1.set(true);
          s2.set(false);
          s3.set(false);
          s4.set(false);
    public void kickFlyWheel()//DOES EVERYTHING THAT INCLUDES KICKING
        roller.set(.5);
        flyWheel.set(-1*sensitivity2);
        if(((stickLeft.getRawButton(1))))
            roller.set(0);
            Timer.delay(.5);
              s2.set(false);
              s1.set(true);
            Timer.delay(.75);
            s1.set(false);
            s2.set(true);
         roller.set(.5);
    public void robotInit() //Initializes functions prior to start of the match
        getWatchdog().setExpiration(0.2);
        Timer.delay(10.0);
        cam = AxisCamera.getInstance();
        cam.writeResolution(AxisCamera.ResolutionT.k320x240);
        cam.writeBrightness(0);
        gyro.setSensitivity(.007);
        turnController.setInputRange(-360.0, 360.0);
        turnController.setTolerance(1 / 90. * 100);
        turnController.disable();
       Airsystem();
//Strafing
    public void mecanumDrive()
        y1= -1* stickRight.getY();
        x1=  -1*stickRight.getX();
        y2= stickLeft.getY();
        x2= stickLeft.getX();
        sensitivity1= -1*((((stickRight.getRawAxis(3))+1)/2)+.01);//Throttle is now
                                                             //from 1% to 100%
        sensitivity2= -1*((((stickLeft.getRawAxis(3))+1)/2)+.01);//Throttle is now
                                                             //from 1% to 100%
        rightBackSpeed = sensitivity1*(y1-x1);
        rightFrontSpeed = sensitivity1*(y1+x1);
        leftBackSpeed = sensitivity1*(y2+x2);
        leftFrontSpeed = sensitivity1*(y2-x2);
        rightBackJaguar.set(rightBackSpeed);
        rightFrontJaguar.set(rightFrontSpeed);
        leftFrontJaguar.set(leftFrontSpeed);
        leftBackJaguar.set(leftBackSpeed);
    public void autonomousPeriodic() {
        try {
            //Camera crapthingy
                if (cam.freshImage()) {// && turnController.onTarget()) {
                    double gyroAngle = gyro.pidGet();
                    ColorImage image = cam.getImage();
                    Thread.yield();
                    Target[] targets = Target.findCircularTargets(image);
                    Thread.yield();
                    image.free();
                    } catch (NIVisionException ex) {
                        ex.printStackTrace();
                    } catch (AxisCameraException ex) {
        //End camera crapthingit
        if ((i1.get())&&!(i2.get()))
           // Front position Autonomous code
        if (!(i1.get())&&!(i2.get()))
           // Middle position Autonomous code
        if (!(i1.get())&&(i2.get()))
           // Far position Autonomous code
     * This function is called while the robot is disabled.
    public void disabledPeriodic()
   // airCompressor.setRelayValue(edu.wpi.first.wpilibj. Relay.Value.kOff);
     * This function is called at the beginning of teleop
    public void autonomousInit()
   public void compressorCheck() //turns on/off compressor based on full
       if (airCompressor.getPressureSwitchValue()) {
            } else {
            airCompressor.setRelayValue(edu.wpi.first.wpilibj. Relay.Value.kOn);
    public void teleopInit() {
    boolean lastTrigger = false;
     * This function is called periodically during operator control
    public void teleopPeriodic() {
        getWatchdog().feed();
        long startTime = Timer.getUsClock();
        //Canera
            try {
                    Thread.yield();
                    Thread.yield();
                    image.free();
            Thread.yield();
            mecanumDrive();
            Thread.yield();
            kickFlyWheel();
            Thread.yield();
            //pneumaticsKicker();
            compressorCheck();
            Thread.yield();
           // System.out.println("Time : " + (Timer.getUsClock() - startTime) / 1000000.0);
            //System.out.println("Gyro Angle: " + gyro.getAngle());
A Captian and Driver Issue R.C. General Forum 26 27-10-2010 00:41
Driver Station Missing 'nicyapi.dll' Issue. Twisted eric Programming 4 14-02-2010 21:14
2009 Driver Station Issue EricWilliams Control System 5 22-01-2010 14:59
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver Station Watch Dog / Motor Won't Spin Issue RMiller FRC Control System 5 20-01-2009 09:58
