Go to Post DONT USE ROBOTS FOR EVIL!!! - Cooley744 [more]
Unread 19-02-2010, 14:32
Yuan Xue Lim's Avatar
Yuan Xue Lim Yuan Xue Lim is offline
Electrical Programmer
FRC #3017 (Project Genesis)
Yuan Xue Lim is an unknown quantity at this point
Send a message via AIM to Yuan Xue Lim
Jaguars won't take in any negative values
Yesterday night, our team was testing the kicker. It was working fine at beginning.However, halfway through the testing, it just won't take in negative values. Not even the jaguars are flashing red to represent negative values.
Values from 0~1 works fne. Does this have to do with the encoder? We tried it with the encoder off and it still gives the same problem.
P.S the motors work fine with joysticks.
[font="Fixedsys"][b]We Don't Hope We will.
Unread 19-02-2010, 15:43
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
Re: Jaguars won't take in any negative values
check the limit switch jumpers to make sure that one didn't get removed by mistake
Unread 19-02-2010, 15:46
I check all of them( if you are talking about the jumpers on jaguars) and it is all fine,none was removed.
Unread 19-02-2010, 15:48
Zme Zme is offline
FRC #2619
ok reread your post, if the LED's arn't lighting up red then there is a different issue, check through your code and make sure you don't clip the outputs anywhere, you might also want to be sure that the code isn't suffering any major errors when you try to drive backwards and (because i don't know if they would trip the led or not) make sure a soft limit didn't get set
Unread 19-02-2010, 16:41
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
When you say negative values does this mean your motor can't spin in one direction? I ask this because yesterday the programming team ran into a bug where one of the wheels could not spin backwards. A mentor tested one of our Jaguars with a voltmeter and found out it was broken. I'm guessing yours is to.
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 19-02-2010, 22:59
But we did try that jaguar with joystick and it works fine. Right now is not just one jaguar is all the jaguars won't take in negative values other than the one from joystick.
Unread 20-02-2010, 10:58
FRC #2423 (KwarQs)
Yesterday, our electronics guy checked out the jaguar and found out it had been wired incorrectly. I don't think this is a programming issue, I think someone on your team needs to check if your jaguar(s) is wired correctly. If Sorry if my advise isn't very helpful. If you haven't I think you should post this same thread in the electrical forum, see if more people will help you over there.
KwarQs 2423
Unread 20-02-2010, 13:31
We just solved the problem.It wasn't the jaguar.It was the program. I shouldn't have set the PWM into 0 outside the if statement after the trigger or button was pushed.
Thank you all for helping me out.
I represent team #3017 to thank you all.
Can't see any values on dashboard kevinb999 C/C++ 11 03-02-2010 14:41
Negative Repping... Cody Carey General Forum 21 29-03-2007 18:42
Take some time, read the manual, take a breather, and calm down. Elgin Clock General Forum 8 08-01-2006 18:35
Negative Scoring Mr.G Rules/Strategy 16 14-02-2005 11:02
Negative Bus Greg General Forum 3 03-02-2003 07:33
