Go to Post ...Of course, all the scales in the world won't help you if your robot is 135lb two nights before the ship date... - J Flex 188 [more]
Unread 19-02-2010, 16:06
K Lenox's Avatar
K Lenox K Lenox is offline
I AM GOD IN GEARS OF WAR!!!!
FRC #2632 (Comets Unleashed)
K Lenox is an unknown quantity at this point
How do I tell labciew to make the robot kick once?
I am a noob at LabVIEW. How do I tell the robot in LabVIEW to kick the ball?
We are using motors. And I want to move forward for 1 second and then kick the ball. How do I do it?
Thx
Kyle Lenox
[font="Times New Roman"]
You never saw this message
You never read this
You will read the next available object within sight
Why are you still reading this???  Begone with you!!!
[SIGPIC]
Unread 19-02-2010, 16:52
Racer26 Racer26 is offline
Re: How do I tell labciew to make the robot kick once?
You're definitely going to have to give us more info than that.
How is your kicker set up?
What motors does it use?
How do they affect the motion of the kicker?
How is it latched?
What ports does its motor connect to?
Unread 19-02-2010, 17:32
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Thx
Kyle Lenox
Can you add any additional information than you did in this post.
http://www.chiefdelphi.com/forums/sh...ad.php?t=81938
Like 1075guy said and others have said, we need to know more about the hard ware you are using to kick the ball.
If you were going to control the motors manually and not through LabVIEW,
What actions would you need to do to kich the ball with your hardware?
If you can write the steps down and post them then, I am sure one of us could tell you how to code it.
Omar
How do you make the robot turn a perfect 90 eccmaster Programming 2 16-01-2008 20:54
How will the Balls Change once FIRST Paints them Mr.G General Forum 28 24-01-2006 23:07
how do i tell to the edurc when the remote is on. Code\\Pilot Programming 4 28-01-2004 21:00
How do you tell whether your sensor is detecting a crate or the diamond plate? Greg Ross Technical Discussion 4 13-01-2003 19:02
ONCE AGAIN, EVERYONE TELL ME THE ANSWER! =) archiver 2001 2 24-06-2002 02:42
