Go to Post A Red Ryder 200-shot carbine Range model air rifle!!! - dlavery [more]
Unread 19-02-2010, 17:44
dnrobotics11 dnrobotics11 is offline
FRC #2589
dnrobotics11 is an unknown quantity at this point
Pneumatics Code Questions
Hey everybody,
I have two questions about the pneumatics code in C++. First of all, when you are initializing the solenoids with the "s = new Solenoid(x, y)" statement, what are the two arguments 'x' and 'y'? One of them is clearly the digital port on the cRIO but what is the other and what is the order of them?
Also, on the cRIO, one of the PLCs (or whatever they are called) is made for the solenoid ports. Which slot does this go into on the cRIO board?
Thanks for the help!
Unread 19-02-2010, 18:31
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
Re: Pneumatics Code Questions
The solenoid module goes into slot 8 on the cRIO by default. If you have a second solenoid module, put that into slot 7. Every solenoid connected to one module has to operate on the same voltage e.g. all 12V or all 24V.
  Solenoid *m_solenoid_1;
  m_solenoid_1 = new Solenoid(1);
That code assumes the solenoid module is in slot 8. You only need to two argument version if you are also using slot 7.
Unread 19-02-2010, 18:36
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
for a solenoid on module 8, connected to the first set of pins, Solenoid(8,1), or you can abbreviate it Solenoid(1) if it is on module 8
Watchdog.Kill();
Unread 20-02-2010, 10:16
FRC #2589
thanks so much for the help everybody
Pneumatics Code dnrobotics11 C/C++ 5 15-02-2010 19:29
Pneumatics Code nighterfighter C/C++ 16 12-10-2009 17:52
questions regarding <R73> [pneumatics rules] smcmahon Rules/Strategy 3 16-02-2009 12:47
Pneumatics Questions RAWdealer59 Pneumatics 1 17-02-2003 12:10
Pneumatics parts list questions archiver 2000 1 23-06-2002 22:48
