Go to Post DO NOT THROW THINGS AT THE PROGRAMMER! - demosthenes2k8 [more]
Unread 19-02-2010, 17:37
Twisted eric's Avatar
Twisted eric Twisted eric is offline
FRC #0581
Twisted eric is an unknown quantity at this point
Exclamation Crio problems
We are having troubles with out Crio we have tried virtual every thing it will keep dropping the code every sec.
Post any ideas we will try them all (with in reason) if we don't fined out I don't know what we will do.
Unread 19-02-2010, 17:41
All Bones's Avatar
All Bones All Bones is offline
FRC #0302
All Bones is an unknown quantity at this point
Re: Crio problems
Heres an idea, is the crio faulty? have you tried to see if it even works on its own? i know u probably already tried this but its an idea.
Someday someone on a robotics team is going to see a button and not have any idea what it does, press it, and destroy the world. And that's how technology will kill us all
Unread 19-02-2010, 17:44
FRC #0581
Re: Crio problems
define
Unread 19-02-2010, 18:45
FRC #0581
Re: Crio problems
I forgot to mention we are having the OTA problem and the crio is continually dropping the code.
Unread 19-02-2010, 19:24
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: Crio problems
Can you better define what you mean by, "Dropping the code?" Also, I don't know what you're referring to by OTA, sorry.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 19-02-2010, 19:28
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Wolfgang is an unknown quantity at this point
Re: Crio problems
Well, does your robot accumulate a lot of static electricity? I am not sure, but I have heard that static can cause some parts of the bot to malfunction. To solve this problem, my team decided to attach an open wire from the center of the bot underneath and then let it dangle and touch the ground. I have heard certain wheels can be a primary cause of static electricity.
Unread 20-02-2010, 15:20
FRC #0581
Re: Crio problems
Thanks all for helping a mentor came and helped us with the problem
Unread 20-02-2010, 16:43
dman14 dman14 is offline
AKA: Darren Stahl
FRC #4783 (FRC #1305 Alumni)
dman14 will become famous soon enoughdman14 will become famous soon enough
Re: Crio problems
Can you please post how it was fixed? We are having what sounds like the same issue, and can't seem to get it fixed.
Unread 20-02-2010, 20:35
chris janney chris janney is offline
FRC #3266
chris janney is an unknown quantity at this point
Re: Crio problems
seems like a lot of people are having a problem with their crio. mine simply wont turn on. any suggestions?
Unread 21-02-2010, 01:33
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: Crio problems
check the battery, 9/10 times, its the battery (compressors eat battery)
cRio problems blazingshadow Programming 2 31-01-2010 17:18
cRio Problems tanguma26 Inventor 3 25-01-2010 13:19
cRio problems tanguma26 Programming 4 21-01-2010 21:09
cRio Code problems Aaron V FRC Control System 2 14-01-2010 12:59
cRIO Problems computerboi1503 C/C++ 7 11-01-2009 09:35
