Go to Post Well, air conditioners when pointed inside the house make it cooler. So I figure if EVERYONE turns their air conditioners on full blast and just point them out the window, we should more or less get rid of this "warming" nonsense. - Mike [more]
Unread 19-02-2010, 19:09
Free Willy's Avatar
Free Willy Free Willy is offline
Free Willy is an unknown quantity at this point
KOP gearboxes and FisherPrice Motors
Is there a way to attach a fisherprice motor to the gearbox from the KOP? Or is there a simple way to attach the fisherprice gearbox to the KOP gearbox?
Unread 19-02-2010, 19:15
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: KOP gearboxes and FisherPrice Motors
If you have the time, the easiest and cleanest way to do it.
Would be to buy this:
http://andymark.biz/am-0347.html
This is a FP planetary which has the same mounting holes as a CIM, so it would mount to the Toughbox super easy.
-RC
R.C.
MadTown Robotics Team 1323
Unread 19-02-2010, 19:17
EricH EricH is online now
Not directly.
Try an AndyMark Planetary gearbox; it'll slow the FP down a bit, but should do the trick.
Or you could make an octagonal FP gearbox-shaft coupling and use that to drive the Toughbox.
Extra gearboxes needed, KOP sprockets and wheels available in Suffolk County, NY dmlawrence Kit & Additional Hardware 2 07-01-2008 10:24
Which pinions for FP motors and BaneBots 42 mm gearboxes? Madison Technical Discussion 3 23-01-2007 20:04
KOP Gearboxes and noises David Sherman Kit & Additional Hardware 8 29-01-2006 13:37
Motors and gearboxes from the kit Kam1310 Motors 21 10-03-2005 22:26
Motors and gearboxes in the kit Kam1310 Technical Discussion 1 09-03-2005 17:43
