Go to Post "Simple" is about staying within boundaries. - dtengineering [more]
Unread 19-02-2010, 19:32
The Last Don's Avatar
The Last Don The Last Don is offline
Illegal Immigrant
AKA: Alexander Calderon
FRC #2647 (North2 D2)
The Last Don is an unknown quantity at this point
Send a message via MSN to The Last Don
Exclamation Joystick Problem
Hi There,
Im having problem with the joystick. I have program the robot to move in tank drive, but the problem is that when move one of the Joystick, the jaguar do not read the signal.
I could only go forward when I move the left Joystick forward and the right joystick sideways.
Later on I going to post a screen shot of the programming of the tank drive. Hoping that would help.
Unread 19-02-2010, 19:36
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Wolfgang is an unknown quantity at this point
Re: Joystick Problem
From what it sounds like, you may have wired the x-axis value on the joystick to make the robot's right motors move. If this is not the problem, then it may not have to do with the code at all.
Unread 20-02-2010, 02:19
Illegal Immigrant
Here are the screen shot that i promise. Hopefully they would help breaking down this problem.
ID:	8724  Click image for larger version
ID:	8725  Click image for larger version
Unread 20-02-2010, 16:27
Illegal Immigrant
Thank you, this have help me alot. I have found the X-axis value and change them into the y-axis value. I appreciate your help, Thank you.
Joystick Problem The Last Don Programming 2 13-02-2010 13:13
Joystick Communication Problem mechatronics NI LabVIEW 4 03-02-2010 20:25
Problem with Joystick Throttle ctcw Java 2 15-12-2009 19:11
Joystick problem Team_136 Control System 0 14-01-2009 16:02
joystick problem archiver 2000 12 23-06-2002 23:08
