Go to Post Whatever the rule, MAKE IT CLEAR. - Bill Beatty [more]
Unread 19-02-2010, 20:13
chris janney chris janney is offline
FRC #3266
chris janney is an unknown quantity at this point
wiring help
hi all
i have a problem. well two of them. the first one is i dont know what the cable looks like that connects the solenoid to everything. the second is my team doesnt understand the meaning of team work. any solutions for both of them. thx
Unread 19-02-2010, 20:19
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: wiring help
Solenoid connections?
There should be some cables in your kit that look like PWM cables, except with 2 connectors.
If you are using the 2010 KOP solenoids, you can connect the input of the Solenoid board to the 24vdc supply for the cRio, if you are using 12v solenoids you can connect to the 12vdc supply.
If you are using the 2010 KOP solenoids, you should be able to connect one end of the cable directly to the solenoid and the other end directly to the Solenoid board. It should fit. You need two cables, since the KOP solenoid is a double solenoid.
I don't know about your teamwork problem. Sorry.
Kettering Motorsports
Unread 19-02-2010, 21:16
FRC #3266
Re: wiring help
thanks that helped out a ton.
any other advice would be welcome.
thx
Unread 19-02-2010, 21:21
Joe6391 Joe6391 is offline
Joe
AKA: Joe
FRC #1361
Joe6391 has a spectacular aura aboutJoe6391 has a spectacular aura aboutJoe6391 has a spectacular aura about
Re: wiring help
Teamwork problems... Hmm...
Promote synergy? (like a boss)
Unread 20-02-2010, 00:02
spaztec's Avatar
spaztec spaztec is offline
Electrical Pit Crew
AKA: Luke
FRC #0069 (Hyper)
Team Role: Electrical
spaztec is an unknown quantity at this point
Send a message via AIM to spaztec
Re: wiring help
take a hollow aluminum block, 1"x3"x2'6", custom fit a hand sanded handle from a solid block of wood, and promote teamwork with it
2007 Boston Regional Champion
2005 California Regional Champion
2005 Connecticut Regional Champion
2004 California Regional Champion
2004 NH Regional Regional Champion
2002 Connecticut Regional Champion
2001 Connecticut Regional Champion
Unread 20-02-2010, 00:09
KC1AJT's Avatar
KC1AJT KC1AJT is offline
Head Mentor
AKA: Patrick
FRC #6617 (Bellinghan High School Black Hawks Robotics Club)
KC1AJT is an unknown quantity at this point
Re: wiring help
In my opinion, if someone isnt working...send them home thats exactly what my team does. see how your team reacts to you saying that if anyone isnt working, they get sent home
Mentor - Team 6617
_____________________________________________
Student Years - Team 61
2011 Boston Regional
2011 BAE Systems/Granite State Regional
2010 Northeast Utilities FIRST Connecticut Regional Finalist
2010 Boston Regional
2009 Archimedes Division
2009 Connecticut Regional
2009 Boston Regional Regional Winner
Unread 20-02-2010, 00:14
apalrd's Avatar
More Torque!
VRC #3333
Re: wiring help
We've found that plastic cable chain makes a great whip.
(Then we toured Diamond Moba, a company that makes industrial egg-handling robots, and they had really really big pieces of that stuff, like 12"x3" cross-section several feet long. I wonder how that would work as a whip...)
Unread 20-02-2010, 02:45
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: wiring help
I prefer pool noodles. We have plenty extra (we found a good deal and decided to stock up for a few years), they're light weight, make a good "thwack" when they make contact, don't inflict permanent injury. The person you target gets the point... and the "thwack" reminds everyone else in the room while your at it
Unread 22-02-2010, 17:59
FRC #3266
Re: wiring help
thanks for the advice all. i hope i dont have to use it, as our team has started mending our issues. thanks all.
Unread 22-02-2010, 20:30
viper110110 viper110110 is offline
FRC #1325
viper110110 has a spectacular aura aboutviper110110 has a spectacular aura aboutviper110110 has a spectacular aura about
Re: wiring help
Our team has discovered (the hard way) that PWM cables are very painful. We also use pool noodles.
Servo Wiring Help Schnabel Motors 2 09-05-2009 02:57
Help with Wiring diesel Electrical 0 16-02-2008 12:42
Compresser Wiring Help Hastypickle Electrical 3 02-02-2008 19:16
HELP...Wiring Problem neslo89 Inventor 0 11-03-2006 09:16
HELP! We need pneumatic wiring help! BrittanyV Pneumatics 13 10-03-2006 09:26
