| Thread Tools |
Rating:
Display Modes |
Inspection Checklist posted!
The official FRC 2010 inspection checklist has been posted on the Game Manual page:
http://usfirst.org/uploadedFiles/Com...%20Rev%20A.pdf |
Re: Inspection Checklist posted!
Please keep in mind that this is only rev A and rev B is already in the works.
That being said, I'm sure that all of the Robot Inspectors will value your constructive input. Thanks, Mike |
I like it! The ??? for software versions is a humorous touch (although I doubt it was intended that way)
[Accent] No inspection sticker for you... Two days... [/Accent] ![]() |
In the same area is the new Rev J of the robot rules Section 8. Please be aware that changes to the robot rules will be enforced at events. Inspectors will use the latest version of the rules and the inspection checklist at each event. Read and compete.
I have a question on "Intrusion of Balls Inside FRAME PERIMETER" - isn't that only a rules violation and penalty if it happens? It says under normal operation - couldn't your normal operation (by design) be to drive away from any ball headed for some area of your robot? I understand inspecting for this and flagging it to the officials, but it should not prevent the robot from failing inspection.
#7
Min of 12 gauge wire for 40 amp breaker?
so 14 is not ok? Or am I reading it wrong? |
#8
Mike |
#9
This thread seems to suggest that the CIM motor wires are an exception: http://www.chiefdelphi.com/forums/sh...ad.php?t=82190 ~ |
#10
Ugh. We did all the 40 amps to the jags (there all jags...) in 14.....
#11
Better to find out now when you have a few days to fix it, then at the competition.
#12
We don't even have any 12.
#13
Then use 10; you got 10 feet each of red and black in the Kit of Parts.
#14
Gary,
Regarding the distinction between CAPABLE and NOT INTENDED TO with respect to having balls intrude by more than 3" and whether such capability (regardless of intention) is a violation of rule <R19> (see below) - this sounds like a great question for the GDC and the formal Q&A. When I read the rules and crafted the checklist task, I interpreted the rule such that simply having the ability to intrude by > 3" was a violation of <R19>. It can get even fuzzier - I saw a few robots at Suffield Shakedown with "squishy" barriers around their robot's lower perimeter (eg rubber bands or belts). It was very easy for the robot to "hop" over a ball and trap it underneath (even though, under normal operation, the "squishy" barrier did a fine job of keep balls from being lodged under the robot). In this case, I would have been tempted to allow the robot design to pass inspection and left enforcement of the (hopefully rare) ball entrapments to the referees. A formal Q&A thread sounds like an appropriate action to take. Russ <R19> ROBOTS must be designed so that in normal operation BALLS cannot extend more than 3 inches inside a) the FRAME PERIMETER below the level of the BUMPER ZONE (see Figure 8-5), b) a MECHANISM or feature designed or used to deflect BALLS in a controlled manner that is above the level of the BUMPER ZONE. |
#15
For those 4-H teams, have you used 4-H as your school name also?
Thank you, Trying to Help |
| Robot Size- R11 vs. Inspection Checklist | Toby314 | Rules/Strategy | 4 | 07-01-2008 10:09 |
| Robot Inspection Checklist | ChuckDickerson | Technical Discussion | 2 | 16-02-2006 21:30 |
| Update 11 is posted, with Inspection Checklist | Tristan Lall | General Forum | 2 | 15-02-2005 21:34 |
| Inspection Checklist Draft Available | Yan Wang | General Forum | 1 | 26-02-2004 20:14 |
| Have you seen the Inspection Checklist? | Matthew_H | General Forum | 20 | 23-02-2003 19:55 |
