Go to Post As to "no fasteners," I have a gallon of epoxy, and I'm not afraid to spread it. - Rick TYler [more]
Unread 19-02-2010, 20:24
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
Image cRIO daily?
Here Down Under we have been busy getting our robot ready to ship. (We have decided to ship a day early to give Wombot an extra day to clear customs.) We found that we need to re-image the cRIO almost everyday! When we don't re-image the cRIO we get "No Code" errors. We are running the latest version of the WPIlib, and images for the cRIO and Classmate PC. Have you encountered a similar problem?
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 19-02-2010, 21:37
Joe6391 Joe6391 is offline
Joe
AKA: Joe
FRC #1361
Joe6391 has a spectacular aura aboutJoe6391 has a spectacular aura aboutJoe6391 has a spectacular aura about
Re: Image cRIO daily?
I have personally only had to image the cRIO when an update was required...
Are you sure you are undeploying and downloading correctly?
Unread 19-02-2010, 22:44
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
What language are you using? In labview, running the code using the run arrow does not deploy it.
Likewise, if you are not Building it, then using "Run as startup" instead of just "Deploy" you will see that issue. (In labview only - I can't speak to the other languages).
Unread 20-02-2010, 00:11
We are using C++, and every time we download we undeploy first. Last year, I had no problem using the same system. Any ideas?
Sarah Heimlich
FIRST® TEAM 3132
Unread 20-02-2010, 00:43
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Hm... Have you tried downloading it multiple times in a row without undeploying it?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 20-02-2010, 12:49
Joe
AKA: Joe
FRC #1361
Did you try hooking up your cRIO to a hypertermnial to your computer?
That would show you if the code is downloading correctly.
Sometimes a code will build fine, but have errors anyways. We had some problems with our autonomous and that.
Saving an image to the Crio Tom Line NI LabVIEW 2 01-01-2010 11:31
cRio doesn't re-image Lilszamora FRC Control System 3 15-02-2009 21:06
Crio image download brainsdmaner FRC Control System 2 15-02-2009 01:06
cRIO Image version? Chris11246 Programming 1 14-02-2009 16:44
Unable to re-image cRIO slavik262 FRC Control System 4 09-12-2008 21:05
