Go to Post The best revenge is living well. - gblake [more]
Unread 19-02-2010, 21:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Inspection Checklist posted!
The official FRC 2010 inspection checklist has been posted on the Game Manual page:
http://usfirst.org/uploadedFiles/Com...%20Rev%20A.pdf
Unread 19-02-2010, 21:54
Electrical Engineer
Rookie Year: 1995
Re: Inspection Checklist posted!
Please keep in mind that this is only rev A and rev B is already in the works.
That being said, I'm sure that all of the Robot Inspectors will value your constructive input.
Thanks,
Mike
Mike Betts
As easy as 355/113...
Unread 19-02-2010, 22:02
MrForbes's Avatar
AKA: Jim
I like it! The ??? for software versions is a humorous touch (although I doubt it was intended that way)
Unread 19-02-2010, 22:20
Electrical Engineer
Rookie Year: 1995
You mean that ??? is not the version you are running?
[Accent]
No inspection sticker for you... Two days...
[/Accent]
Mike Betts
Unread 20-02-2010, 01:45
In the same area is the new Rev J of the robot rules Section 8. Please be aware that changes to the robot rules will be enforced at events. Inspectors will use the latest version of the rules and the inspection checklist at each event. Read and compete.
Unread 20-02-2010, 07:41
Generator of Entropy
FRC #2973 (The Mad Rockers)
I have a question on "Intrusion of Balls Inside FRAME PERIMETER" - isn't that only a rules violation and penalty if it happens? It says under normal operation - couldn't your normal operation (by design) be to drive away from any ball headed for some area of your robot? I understand inspecting for this and flagging it to the officials, but it should not prevent the robot from failing inspection.
Unread 20-02-2010, 18:59
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Min of 12 gauge wire for 40 amp breaker?
so 14 is not ok?
Or am I reading it wrong?
Unread 20-02-2010, 19:08
Electrical Engineer
Rookie Year: 1995
so 14 is not ok?
In accordance with <R47>:
<R47> All active Power Distribution Board branch circuits shall be wired with appropriately sized wire:
A. 12 AWG (2.052mm) or larger diameter wire must be used for all circuits protected by a 40A circuit breaker.
B. 14 AWG (1.628mm) or larger diameter wire must be used for all circuits protected by a 30A circuit breaker.
C. 18 AWG (1.024mm) or larger diameter wire must be used for all circuits protected by a 20A circuit breaker.
D. 20 AWG (0.8128mm) or larger diameter wire must be used for the power connection between the Power Distribution Board and the cRIO-FRC .
E. 20 AWG (0.8128mm) or larger diameter wire must be used for the power connection between the Power Distribution Board and the Linksys Wireless Bridge
F. 20 AWG (0.8128mm) or larger diameter wire must be used for the power connections between the Power Distribution Board and the Analog Breakouts and/or Solenoid Breakout if individual power feeds are used. 18 AWG or larger diameter wire must be used if a common power feed is used for multiple breakouts.
G. 24 AWG (0.5106mm) or larger diameter wire must be used for providing power to pneumatic valves.
14 AWG wire gets a 30 amp (or smaller) circuit breaker.
Mike
Mike Betts
Unread 20-02-2010, 21:31
so 14 is not ok?
This thread seems to suggest that the CIM motor wires are an exception:
http://www.chiefdelphi.com/forums/sh...ad.php?t=82190
Unread 20-02-2010, 22:17
AKA: Brandon Liatys
Ugh. We did all the 40 amps to the jags (there all jags...) in 14.....
Unread 20-02-2010, 22:29
Better to find out now when you have a few days to fix it, then at the competition.
Unread 20-02-2010, 22:32
AKA: Brandon Liatys
We don't even have any 12.
Unread 20-02-2010, 22:47
Then use 10; you got 10 feet each of red and black in the Kit of Parts.
Unread 21-02-2010, 15:27
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Gary,
Regarding the distinction between CAPABLE and NOT INTENDED TO with respect to having balls intrude by more than 3" and whether such capability (regardless of intention) is a violation of rule <R19> (see below) - this sounds like a great question for the GDC and the formal Q&A. When I read the rules and crafted the checklist task, I interpreted the rule such that simply having the ability to intrude by > 3" was a violation of <R19>.
It can get even fuzzier - I saw a few robots at Suffield Shakedown with "squishy" barriers around their robot's lower perimeter (eg rubber bands or belts). It was very easy for the robot to "hop" over a ball and trap it underneath (even though, under normal operation, the "squishy" barrier did a fine job of keep balls from being lodged under the robot). In this case, I would have been tempted to allow the robot design to pass inspection and left enforcement of the (hopefully rare) ball entrapments to the referees.
A formal Q&A thread sounds like an appropriate action to take.
Russ
<R19> ROBOTS must be designed so that in normal operation BALLS cannot extend more than 3 inches inside
a) the FRAME PERIMETER below the level of the BUMPER ZONE (see Figure 8-5),
b) a MECHANISM or feature designed or used to deflect BALLS in a controlled manner that is above the level of the BUMPER ZONE.
Unread 21-02-2010, 15:29
Trying to Help Trying to Help is offline
FRC #1729 (Monadnock 4-H Robotics)
Trying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud of
For those 4-H teams, have you used 4-H as your school name also?
Thank you,
Trying to Help
Robot Size- R11 vs. Inspection Checklist Toby314 Rules/Strategy 4 07-01-2008 10:09
Robot Inspection Checklist ChuckDickerson Technical Discussion 2 16-02-2006 21:30
Update 11 is posted, with Inspection Checklist Tristan Lall General Forum 2 15-02-2005 21:34
Inspection Checklist Draft Available Yan Wang General Forum 1 26-02-2004 20:14
Have you seen the Inspection Checklist? Matthew_H General Forum 20 23-02-2003 19:55
